sheepers Posted June 14, 2017 Share Posted June 14, 2017 here's an idea. check the venturine tubes are in the right way round. backwards will give the symptoms you speak of. 1 Quote Link to comment Share on other sites More sharing options...
Minister88 Posted June 18, 2017 Author Share Posted June 18, 2017 Okay, looks like I found the issue. The timing was off 180 degrees hence it idled well when timing was retarded to 30deg. Nothing really wrong with the carbies although it still might need a tune. 2 Quote Link to comment Share on other sites More sharing options...
