  • Replies 148
  • Sunbeam
    149
Engine assembly came to a halt very quickly due to the wrong rod bearings being supplied. Bowden Engine parts to the rescue for a princely $50! Not NOS genuine, but very old Repco with great wax paper packaging!
Number 2 daughter then gave me a hand to put the pistons in.
Then it was time to flip it over, torque the caps and fit the crankshaft gallery plugs with a bit of blue loctite. To my horror it appears the engine shop has defiled my engine with imperial plugs! Aaargh, the shame. This mod will cost me horsepower and probably make it leak oil too.
This operation was not without issues, however. Some way short of the torque wrench going click, the 1/4 inch hex key sheared off and was left flush. My magnet would not retrieve it either!
The broken end wasnt in super tight, but it wasn’t letting go either. I contemplated welding a wire to it for more pull, but discarded that idea. I couldn’t drill it either because the tool steel is very hard. In the end creativity won again. I heated the crank web with my heat gun, and then blasted the broken hex with contact cleaner. My reasoning was that the rapid evaporation of the solvent sucks a lot of heat out which worked! Cold hex, hot plug and out she popped on the end of my magnet. Whew! I also smashed myself in the nose when the hex driver let go and 2 days later my nose still feels bruised.
 I really want to get the head on because the engine has now been sitting partially assembled in my very drafty dusty shed for over two weeks. This brings me to the next problem. The head dowels were wrecked when they were removed and now I can’t find replacements. I’ve phoned a few outfits but nobody seems that interested in helping/too hard basket. The dowels are quite small at 8mm od and quite short (about 15mm) and they are thin walled and hollow. They need to be hollow as it seems they are located in the oilway… Now I’m not an engineer so I’m just spit ballin here… but is it a dumb idea to cut up an 8mm roll pin and use that as a dowel?
Anyhoo, to plug another hole I offered up the new water pump to the block aaaaand bugger… The impeller fouls the block!
Run it and let it create its own clearance? Skim some material off? Get another pump? Advice welcome.
  • Like 8
  • Sad 1
Scope creep. It happens to the best of us. I was going to run the steering and front suspension as is with just some new bottom ball joints, but after a close inspection I just couldn’t do it.
Also, you couldn’t even see the shape of the steering box under all the crud and filth, but you can now!
To get it all apart was a mission. I decided to remove all the bushes as they looked yuck. This took spanners, a heat gun, hole saw, hack saw, sabre saw, hammer and punches and about 5 hours!
4D085024-25E7-4B54-8BFD-0C3CEC0DDDF2.jpeg.19059c2fb774f6c6dd3f4479b1931a7b.jpegAA76D299-7A21-4E80-925B-8B6DBBC46A73.jpeg.7adce6388e71186149f92b9d28d9df3e.jpeg2BD225E1-A7A4-4764-973E-5C815645711B.jpeg.0391af35402c7d8f2ae3489a01921375.jpeg46327888-47DF-415C-A344-A8526DE89DE2.jpeg.c265b55c44761478dea601365c4cbb32.jpeg0717707E-7294-4EEF-ADD1-6A2DF39B4066.jpeg.4ac5c94902b0f4590535843feae9b261.jpeg
And this is a bit baffling, it looks as though some creature has cut into the lower ball joint spindle on the upright…
It sounded a bit noisy I think. I pulled the exhaust off again because I wasn’t super happy with how it was fitting. I noticed this. C184FB3E-EDF6-42E8-834C-4A77E400F16C.thumb.jpeg.7aad36f606c97063c01fad00b39d8119.jpeg
it’s touching the bellhousing. Not good, and it certainly didn’t touch there originally so I’m a bit baffled as to how this happened. There was clearly exhaust leaking from the engine block side of the flange. This makes sense because the fouling on the bellhousing will stop that side doing up tight. Remember how I said some moron had welded the front slip joint? I decided to unweld it. All the subsequent tricks in the book would not separate the join so I cut it and oh, looky here…
collector side
pipe side:
Great. The exhaust pipe is puny 38mm i.d. pipe (stainless actually!) and this clearly would not fit over the collector. So, of course any sane person would smash the collector pipe into star shaped oblivion until it does fit. Aaaaargh! This will undoubtedly turn into a wallet-rending drama.
  • Sad 1
