malarky Posted November 30, 2016 Share Posted November 30, 2016 Soo, I'm wanting something to eat away rusty bits before I can weld in new metal, will this be any good for several patches and then selling/passing off http://mytools.co.nz/products/sandblaster-kit I guess it's a step up from those handheld Supercheap doodads but is it up to the job? Quote Link to comment Share on other sites More sharing options...
Bling Posted November 30, 2016 Share Posted November 30, 2016 Are you talking about on a chassis or something you can't put in a booth? I had a supercheap handheld gun in a cabinet, never had any issues with it. IT was just a basic pistol + suction pipe setup. If you're doing it outside, then you'll want to have some respirator half mask or similar if using sand. I had some pink garnet in my cabinet as I don't think it's as bad for you as sand. But it was a sealed booth, so don't take my word on that. tl;dr even basic sandblast tools work, it's just sand blown by air after all. Quote Link to comment Share on other sites More sharing options...
Mickey Posted November 30, 2016 Share Posted November 30, 2016 If you want a quality but basic unit then Syntech do one that's just a gun with a hose. You put the end of the hose into your bucket of garnet and sand away. I wouldn't go anywhere near using normal sand for blasting due to the dangers of silicosis. More info here: https://www.cdc.gov/niosh/docs/92-102/ Use garnet which Syntech can supply you also. Comes in sacks in 3 different grades if I remember correctly. Let them know what you're doing and they can advise you on the correct grade. http://www.syntechnz.com/ Quote Link to comment Share on other sites More sharing options...
