buzzy Posted October 27, 2016 Share Posted October 27, 2016 Where the best place to mount a Holley fuel pump under the car? Can I mount it to the chassis or is there a better place for it? Cheers Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 27, 2016 Share Posted October 27, 2016 Just follow the instructions and use common sense. If its anything like mine it will need to be as close to below the tank as possible. 1 Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 27, 2016 Share Posted October 27, 2016 What car? Does it already have an electric pump? Is it being used as a lift pump or feeding a carb? To suit EFI or low pressure? Most of the time in the engine bay is the easiest, wiring and plumping is simplified. Biggest thing to remember is the noise, a rubber isolation type mount is needed if you want to hear anything other than the pump. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted October 27, 2016 Share Posted October 27, 2016 it will need to be as close to below the tank as possible. this. they dont like sucking, so near the tank and at the level of fuel, and mount it on rubber insulated mounts 1 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted October 27, 2016 Share Posted October 27, 2016 Pump head down and motor up if it's anything like my old Holley black 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 28, 2016 Share Posted October 28, 2016 Why? Quote Link to comment Share on other sites More sharing options...
