Gas hob install in a bus - a question
ThePog
In my bus i will be running a gas hob only. I have made the box for the bottles to what I believe is the correct spec, and the hob has flame out protection etc.
What i want to know is can I just run a standard gas reg/gas pipe to the hob? There is no physical issue doing this as it is not a long run between one and the other, so it means no need for gas fitting etc. The regulations I have read state a need for all work to be carried out by a gas fitter and then certified, but there is no actual gas fitting required...?
Any of you lot know the rules?
Yep still needs cert install for insurance and safety purposes
Bottle cupboard needs to vent to outside as low as possible
It may just take an inspection on what you have already done
I know a good mobile plumber/gas fitter in your area if want want a number to call?
Yea check with a gas fitter who knows about caravans and stuff.
I had a 30 seater bus in Europe for a few years which had a 30kg bottle in he back. I ran hose to the front and used an airline style quick connect fitting that was made for gas. Also had an outlet on the outside so I could sit the cooker outside when the air temp was 35 degrees plus.
