Right so I have a Mk1 escort 2 door. It has the larger top hat. I want to fit roller top hats and need shorter inserts. Anyone know what the best options are? Have used the search function but some of what I've found is neither here nor there.
I was considering ordering the tophats from burton but if there is a better option?
Not really mate if you want roller top hats the best option is from Burtons or rally design or eBay or even palmside.co.nz.
As for shorter inserts you can get the from the places mentioned above .
I have had a new set of shocks in the past from the shock shop and got them to machine them down to keep the lowered springs captive .
If having them machined down is the way yoi want to go to be honest pretty much any engineering place could do it for you.
I have also heared of poeple using shocks out of toyotas that have been shorter from the factory....but you would need to google that.
Im running them on my daily Mk1 four door , currently have moved them into my racecar for the cert . I can post picture if you want to see them  :thumbleft:
