seatbelt colour change / dye?
rob.121
Rit dye, need to remove the belts from the retractors etc though and I'm not sure how legit it is to do so.
Easy enough to do though if you take your time and wind enough preload back into the retractor, I have striped a set to dye and change buckles on in the past.
where could i get Rit dye from? Did it rub off on the belts you did?
New is an option, but if i can successfully dye the one i have would be ideal
Chemists often stock a limited range, sewing places have shitloads of colours.
Follow the instructions, use the right amount of salt and rinse well, didn't have any problems with it rubbing off.
Only use Rit though, the other common one (dylon?) is for natural fibres and if you can even get it to work will rub off everywhere!
