SiRge Posted July 20, 2015 Share Posted July 20, 2015 Hi all, For a car that didn't come with side facing indicators (Only has forward and back ones), is it going to be a requirements to retrofit ones on there to get it through compliance? I know I only need 1 rear facing mirror (Which I may end up getting side ones as well), but I can't remember the requirements for side facing indicators. Cheers Geoff Offending vehicle: Quote Link to comment Share on other sites More sharing options...
SiRge Posted July 20, 2015 Author Share Posted July 20, 2015 Just found this part from the WOF standards, but I'm not sure if they're going to ping me for a compliance check. http://www.lvvta.org.nz/documents/standards/LVVTA_STD_Lighting_Equipment.pdf Colour of direction-indicator lamps 2.5(3) When operated, a forward-facing direction-indicator lamp fitted to a low volume vehicle must emit flashing light that is substantially white or amber. 2.5(4) When operated, a rearward-facing direction-indicator lamp fitted to a low volume vehicle must emit flashing light that is substantially red or amber. 2.5(5) When operated, if fitted, a side-facing direction-indicator lamp fitted to a low volume vehicle must emit flashing light that is substantially amber. The 'if fitted' part interests me. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted July 20, 2015 Share Posted July 20, 2015 You don't need them. The car was not fitted with side indicators when manufactured. 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted July 20, 2015 Share Posted July 20, 2015 What you have there are the rules for low volume cert. Here are the wof rules https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/lighting/direction-indicator-lamps In NZ you don't need indicator lamps on the side of the vehicle, but if they are fitted (like all modern cars) then they have to work. 1 Quote Link to comment Share on other sites More sharing options...
