M M Posted May 1, 2015 Author Share Posted May 1, 2015 The Mk1's a 1980 2 door, non sunroof, small tailight with early dash. Just a standard 1.5 diesel. I haven't done anything with it yet (in fact I haven't even picked it up yet, my friend with the diesel has been storing it for me as I bought it off him). It's a decent, pretty much no rust body so I didn't want to miss out on it, especially being an early spec one. Quote Link to comment Share on other sites More sharing options...
tedmunds Posted May 5, 2015 Share Posted May 5, 2015 think im right in saying the small light ones are swallowtails, best ones man. Diesel aswell, what more could you want Quote Link to comment Share on other sites More sharing options...
M M Posted May 5, 2015 Author Share Posted May 5, 2015 think im right in saying the small light ones are swallowtails, best ones man. Diesel aswell, what more could you want Yes exactly, plan is to keep it diesel (like I said, 1.9tdi). The swallowtails are the very early ones, I think up to 76, and then they had small tail light non swallowtail. This is the difference: Swallowtail Non Swallowtail See how there is a curve under the lights whereas on the non swallowtail one there isn't? In my opinion the difference is so small that it's not worth specifically chasing a swallowtail, but cool if you have one. Mine is a 1980 so it isn't. Quote Link to comment Share on other sites More sharing options...
tedmunds Posted May 6, 2015 Share Posted May 6, 2015 Well now i know, thanks for the education man. But yeah, look near enough the same to me Quote Link to comment Share on other sites More sharing options...
M M Posted May 6, 2015 Author Share Posted May 6, 2015 No worries, and yeah exactly. 1 Quote Link to comment Share on other sites More sharing options...
kdotlowe Posted May 7, 2015 Share Posted May 7, 2015 Yo man, Kieran here. Valve cover looks very dope! Quote Link to comment Share on other sites More sharing options...
M M Posted May 7, 2015 Author Share Posted May 7, 2015 Yo man, Kieran here. Valve cover looks very dope! Hey man. Thanks, came out better than I expected. You should do yours the same. Quote Link to comment Share on other sites More sharing options...
fortis Posted May 22, 2015 Share Posted May 22, 2015 Nice conversion, did you have to fabricate the mounts? Quote Link to comment Share on other sites More sharing options...
M M Posted May 22, 2015 Author Share Posted May 22, 2015 Thanks. Do you mean engine mounts? If so then no, Mk2 and Mk3 (as I used here) bolt up to the engine/gearbox and car. Quote Link to comment Share on other sites More sharing options...
PedRac3r Posted May 22, 2015 Share Posted May 22, 2015 Is it just me or is the I/C and rad on the piss? Quote Link to comment Share on other sites More sharing options...
M M Posted May 22, 2015 Author Share Posted May 22, 2015 Is it just me or is the I/C and rad on the piss? Not just you, they're on the piss. From factory the radiator mounts on an angle so I just worked with it. Quote Link to comment Share on other sites More sharing options...
PedRac3r Posted May 23, 2015 Share Posted May 23, 2015 Oh right. It all looks pretty good though, will be interesting to see how it goes once its all sorted. Quote Link to comment Share on other sites More sharing options...
M M Posted May 23, 2015 Author Share Posted May 23, 2015 Oh right. It all looks pretty good though, will be interesting to see how it goes once its all sorted. Thanks. It should be making around 190hp and around 280nm once the tune is flashed onto the ecu. Should be good fun. Decided to go with the Mk4 DBW pedal as I found out today that the one I have on the pedal box won't work with the ECU for this motor, so asked my friend to weld a bracket on for me. Will post pictures tomorrow. Downpipe is also almost done so pictures to come of that as well. Quote Link to comment Share on other sites More sharing options...
ranton Posted May 31, 2015 Share Posted May 31, 2015 Yo man, Kieran here. Valve cover looks very dope! As in lordes brother in law? Quote Link to comment Share on other sites More sharing options...
M M Posted May 31, 2015 Author Share Posted May 31, 2015 As in lordes brother in law? Who's this douche bag? Quote Link to comment Share on other sites More sharing options...
ranton Posted May 31, 2015 Share Posted May 31, 2015 Yes exactly, plan is to keep it diesel (like I said, 1.9tdi). The swallowtails are the very early ones, I think up to 76, and then they had small tail light non swallowtail. This is the difference: Swallowtail Non Swallowtail See how there is a curve under the lights whereas on the non swallowtail one there isn't? In my opinion the difference is so small that it's not worth specifically chasing a swallowtail, but cool if you have one. Mine is a 1980 so it isn't. IMO the swallow tail is ukly AF Quote Link to comment Share on other sites More sharing options...
M M Posted May 31, 2015 Author Share Posted May 31, 2015 I could have bet you'd say that. I wouldn't mind either. Quote Link to comment Share on other sites More sharing options...
Mitchfromhillcrest Posted August 15, 2015 Share Posted August 15, 2015 Duuuude. Did you use the digi fuel pump? Quote Link to comment Share on other sites More sharing options...
M M Posted August 20, 2015 Author Share Posted August 20, 2015 Duuuude. Did you use the digi fuel pump? I swapped in the mk3 tank and used the mk3 pump setup but the Mk2 digifant one should work. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted October 22, 2015 Share Posted October 22, 2015 What's so special about those wheels? You should've let me sandblast them, would've saved you hours of work lol! Should look much nicer on the car once you're done polishing them IMO Quote Link to comment Share on other sites More sharing options...
