Two pot mk10 Villiers
GT_Escortina
Heres some that ive wanted build for sometime (3 ,4 or even 6 cyl) engine but it was hard just finding 2 exactly the same just to start
Im building it in a way so i can keep bolting more cylinders on as i find them
here are some pictures
10830842_1008738059141092_45496829201865
10845893_1016039015077663_47356901552780
there a  spigot to locate the two engines tho i still have to make the bolting plate
10848817_1016038998410998_81166649932112
#1 crank with the center bearing (just noticed it on back to front)
10682351_1016039088410989_26944750762635
1891404_1016039048410993_750197563443110
And as you can see this is the cover
Also im looking for two (will need more later) side draft type carbs from a villiers or similar like this
How are you joining the cranks?
what  i did for the crank was i made a slave with ID undersize to the OD of the stabs left on crank #1 and #2 heated slave to cherry red on a camp cooker and sliped it over crank #1 than crank #2 was machined to a siding fit to slave ,Rod journals set at 180 using Vee block ,dril and taped 2 cap srews {abit rudimentary but it spins ture}
