HighLUX Posted October 18, 2014 Share Posted October 18, 2014 Been doing a manual swap on OS-lockdrifts waka today and everythings gone swimmingly except for the front driveshaft being too long. Used a YX70 wagon for all the donor parts which we thought would make life easy but apparently not as this pic shows Anyone got a lead on what donor to get a front half from? Its the only thing stopping the full powah of 5M magic being unleashed on the world Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 18, 2014 Share Posted October 18, 2014 Yea you notice on the crossmember mounting points the gearbag can be mounted allot further forward for the four banger cars. At a guess you will need a M or G front driveshaft. The Auto shafts sometimes have the same yoke, but Im unsure if the gearboxes are the same length, tried it out? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 18, 2014 Author Share Posted October 18, 2014 Thats auto shaft on the left vs manual from 4 banger on the right so no dice Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 18, 2014 Share Posted October 18, 2014 Does it go in the back of the gearbag? I can't remember details anymore but you could chuck A40 yokes into w50's or w55's. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 18, 2014 Author Share Posted October 18, 2014 Yeah fits fine but its too short. Needs to be a length in between the manual one we have and the original auto one Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 18, 2014 Share Posted October 18, 2014 Well you are boned then, probably 1G manual would be the easiest to find but unsure if they are going to be bang on for a M. Maybe try the dude myk00l on here? he used to have a decent collection of toyota driveshafts. Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 18, 2014 Share Posted October 18, 2014 Just do a mint job and of cut and shutting that Y driveshaft, I'd give it a crack. 1 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 18, 2014 Author Share Posted October 18, 2014 Purrdy much whats going to happen id say. Would of been nice to get it running this weekend Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 18, 2014 Share Posted October 18, 2014 No welder and grinder? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 18, 2014 Author Share Posted October 18, 2014 Yes but owner says no to hori home job. I said fill the shaft with ballbearings before welding it for dynamic balancing but still doesnt think its a good idea 2 Quote Link to comment Share on other sites More sharing options...
be4ver Posted October 18, 2014 Share Posted October 18, 2014 I have a manual d shaft off a manual gx61 with 1g sitting on the floor in my garage. Would ya like me to measure it for you? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 18, 2014 Author Share Posted October 18, 2014 Yes please Quote Link to comment Share on other sites More sharing options...
kpr Posted October 18, 2014 Share Posted October 18, 2014 grinder, welder & dial gauge, problem solved 1 Quote Link to comment Share on other sites More sharing options...
chees- Posted October 18, 2014 Share Posted October 18, 2014 gx71 and gx61s have different length shafts. so thats no good be4ver Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 18, 2014 Share Posted October 18, 2014 grinder, welder & dial gauge, problem solved This, I used to think it was ghetto until I welded one up with a friend. Just do it man. Quote Link to comment Share on other sites More sharing options...
be4ver Posted October 19, 2014 Share Posted October 19, 2014 My one is 675mm end of the yoke to the middke flange Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 19, 2014 Author Share Posted October 19, 2014 Bout the same length as the manual one we already have. Getting it shortened and balanced tomorrow as its easiest way to get it rolling again Quote Link to comment Share on other sites More sharing options...
SRacin Posted October 21, 2014 Share Posted October 21, 2014 I did a manual conversion in one years ago and found one that suits at a van wreckers from some random hiace or liteace van. required the back flange swapped so could change centre bearings and was good to go. Quote Link to comment Share on other sites More sharing options...
