flyingbrick Posted October 1, 2014 Share Posted October 1, 2014 Fuel cell uses -10 an fittings I don't need -10 an hose and don't want to use specialty hoses etc. I need like 100hp worth of fuel not 2000hp. Without welding bits of aluminium tube into each fitting so I can use normal fuel hose (very close to doing this). What are my options? AN fittings honestly make my head hurt. I don't want a fitting on an Albow on an adaptor on a hose tail on a hose.. That will be like 50 bucks! Do plumbing stores stock fittings that will work? Other option is finding a tap that will work and making my own. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 Buy -10 pushloks from aliexpress. 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted October 1, 2014 Share Posted October 1, 2014 you can probably tap the ID of the -10AN fitting to 1/4BSP if you want to be as cheap as possible. if you have two outlets and use both it might be sufficient depending on power level. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 1, 2014 Author Share Posted October 1, 2014 Actually Testament that's a great idea. I will tap the ID and screw in a stainless weld nipple (I think thats what they are called) Why did I not think of that myself herp. At least if I do that then I can use AN fittings on it later if needed. Also, I can get quite a large fitting in there as I can drill the id out a bit before affecting the sealing face/taper Quote Link to comment Share on other sites More sharing options...
Testament Posted October 1, 2014 Share Posted October 1, 2014 That's a much better idea than my ratty, "its midnight need to hit the road in six hours time" solution 1 Quote Link to comment Share on other sites More sharing options...
