Seedy Al Posted February 26, 2014 Share Posted February 26, 2014 Hey guys and guys who dress like girls, I'm just plodding away at some pre cert stuff on my RX30, and one thing that has been bugging me is the pinion angle on the diff head since I have lowered it. Preference is that I dont want to get anything crack tested, because thats just more money lol So I have a few options I guess. One line of thought, was to try find some top arms that are longer, after taking some measurements, it would seem my arms only need to be like 5 to 7mm longer to get pretty good angle. So this made me wonder, does anyone know of any companys that might do an aftermarket offset bushing? I mean, 2 to 3 mm on either bush is fuck all, and would perfectly........ Another option I have been considering, is simply cutting off the rod between the two bushings, buying some stock and welding in new bits that slightly longer, and hoping they wouldnt really notice. these arms are butt welded from factory anyway, so cant be to bad! I dunno, thoughts? or do people happen to have some arms kicking round there shed that they could measure and compare? These ones measured 27.5mm from pin to pin. need to be about 280 to 282mm. However, one cunty thing is that at the diff end, the bolt hole is 14mm and at the chassis end its 16mm. I dont really know if later cressidas or whatever share this sort of desing or not? Quote Link to comment Share on other sites More sharing options...
kpr Posted February 26, 2014 Share Posted February 26, 2014 could get some urethane bushes spun up on lathe. just a matter of setting them up in 4 jaw chuck to get offset center hole. sometimes get lucky and the sticks come in right outer diameter. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 26, 2014 Share Posted February 26, 2014 If you are only needing a few mm, why not move the hole on the diff where the arm bolts on. Slot the hole and weld a washer on in the right spot. I hope that makes sense. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted February 27, 2014 Author Share Posted February 27, 2014 it does make sense. It makes perfect sense even I shall look into this option! Quote Link to comment Share on other sites More sharing options...
