fuck you guys run hard springs in your cars over here for track work. on semi tyres 5.6 in the front and 4 on the back a bigger sway bar up 4 mm thicker and the std sway on the back with good bilstein shocks
I am much happier with mine being 6kg Front, 4kg Rear, instead of the 8, 6.
Just had to raise it a little after swapping them in, as the springs could not hold up the downforce of the car going over dips.
Although even with it a little higher i still had a few sparks fly on a quick run today.
