vivaspeed Posted November 2, 2013 Share Posted November 2, 2013 Here's the dimensions. Ah, that's the diagram I thought I had, have seen it before somewhere. Thanks, I will steal it! Quote Link to comment Share on other sites More sharing options...
Nominal Posted November 3, 2013 Share Posted November 3, 2013 Ah, that's the diagram I thought I had, have seen it before somewhere. Thanks, I will steal it! I think it is out of a Haynes manual or similar. I used to have the manual kicking around, but must have dumped/sold it. Quote Link to comment Share on other sites More sharing options...
Nominal Posted November 3, 2013 Share Posted November 3, 2013 OK, so this is from the NZ Hot Rod mag back in 1985, It is specifically about a Torana, but Viva suspension is very similar. Note that the chassis mounts on the Viva beam are also at the top, above the upper A arm, so you need a chassis/subchassis design that loads it the same way. Quote Link to comment Share on other sites More sharing options...
nzstato Posted November 3, 2013 Author Share Posted November 3, 2013 Ok, this is looking easy. Hard part, triangulated 4 link in the rear? Quote Link to comment Share on other sites More sharing options...
