Michaels 1985 Sigma wagon
michael
Alright sweet will let you know when ive got the 15s on J-W-G
And your right fuel, it is an express. Its also registered as a light van. Its got rear seats and belts, although I suppose they could have been put in at some point during its life
If you can grab these for cheap - http://www.trademe.co.nz/motors/car-parts-accessories/volkswagen/auction-668630231.htm - Use the front springs in the rear.
Ive got unknown brand lowering springs in the rear of mine and it sits perfectly in the spring perches.
For the front cut the springs and get the shock shortened/shorter shocks
  • 4 weeks later...
I I used e30 superlows in the front of mine and cut 1 coil off, rear were ke70 superlow front springs put in the rear with 1 coil off.
and my ex lancer has same frnt setup but 626 superlows that are cut in rear,
basically just find a stiffish spring that fits and cut it so you have low with a stiffer ride, then just get your shocks shortened.
ive had my old wagon go through vtnz like that uncaptive cuts on a pink sticker and pass   so it must be algood with them haha
