michael14 Posted October 21, 2013 Share Posted October 21, 2013 Wouldthe 18r bolt straight up? I have a w50 and the 16r bellhousing in the car at the moment and was just wondering if it would bolt up without any hassles, also whats some easy ways to extract a bit of power out of them. Cheers Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 24, 2013 Share Posted October 24, 2013 i think the 18r will have different engine mounts and bolt pattern. however i have an 18r in an rt84 corona and im happy to take some measurements if you need any. my car was orignally a 6r, but someone changed it, the engine mounts look normal so id say those 2 are swapable. Quote Link to comment Share on other sites More sharing options...
michael14 Posted October 24, 2013 Author Share Posted October 24, 2013 Was mostly just curious haha, as I have an 18r, my corona is 16r which isnt too bad Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 24, 2013 Share Posted October 24, 2013 For some reason I thought the 18r bolted straight in place of a 16r. Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 24, 2013 Share Posted October 24, 2013 The 18r doesnt bolt in place of. 6r? they mount off the front of the engine and 18r is conventional middle of the block. Different gearbox also. have no idea about 16r's if. W50 bolts up its probably the later block and a 18r will work. Quote Link to comment Share on other sites More sharing options...
michael14 Posted October 24, 2013 Author Share Posted October 24, 2013 Yeah w50 bolted straight up to my 16r, something to think about if I wanna cahnge the motor or not Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 24, 2013 Share Posted October 24, 2013 YEa has the later block then so you are all good, early ones have a completely different bellhousing setup. Quote Link to comment Share on other sites More sharing options...
michael14 Posted October 25, 2013 Author Share Posted October 25, 2013 Sweet as cheers mate Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 25, 2013 Share Posted October 25, 2013 The 18r doesnt bolt in place of. 6r? they mount off the front of the engine and 18r is conventional middle of the block. Different gearbox also. have no idea about 16r's if. W50 bolts up its probably the later block and a 18r will work. interesting, must mean mines had the cross member changed too. Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 25, 2013 Share Posted October 25, 2013 Dunno man, its very possible. I have a 18R and a RT40 with a 6R here that I'll be converting, the mounts on the 18R are maybe 150mm back from the factory position. You need to weld some tabs on the x-member to move the mounts back or use some rangi plates. The blocks productions crossed over each other just to confuse everyone so some Coronas/hiluxes whatever will have the 3 main block some the new 5 main block, so easily could have had a crossmember change to make it look factory. Quote Link to comment Share on other sites More sharing options...
