Trick213 Posted September 7, 2013 Posted September 7, 2013 hey, thought id try here before i take it to a shop Wanting to flip my rear leafs in my nissan vanette back to standard and raise the front torsions up half an inch or so, iv got no tools and not entirely sure how to do it but im keen to get stuck in! Can flick sum cash for someones time, id imagine it would take an hour or so? Cheers! Quote
Trick213 Posted September 8, 2013 Author Posted September 8, 2013 cheers for the step by step...although i stated iv got no tools mate! sounds abit sad that iv got no tools really lol Quote
Trick213 Posted September 8, 2013 Author Posted September 8, 2013 wow! thanks mate! lol also need a c clamp, guess your gunna find me one of those to? Quote
kiwi808 Posted September 8, 2013 Posted September 8, 2013 Not taking the piss here but Super Cheap has 20% of everything in store today, perhaps you could swing by and pick up a cheapish socket set to get you on your way. Generally speaking I don't recommend buying cheap tools, but if you don't have any, even a cheap set will get you on your way today. They also do axl stands etc for cheap. My £0.02. 2 Quote
AndyGal Posted September 8, 2013 Posted September 8, 2013 And your raising it up which is a big no no for a start! 4 Quote
hillman1 Posted September 8, 2013 Posted September 8, 2013 What part of Auckland are u in mate and got a contact number I might be able to sort it for u 1 Quote
Truenotch Posted September 8, 2013 Posted September 8, 2013 Also, if you raise it the long u bolts you have now will be (I'd guess) too long. this means to close to the ground. you will need to buy shorter U bolts OR bolt it all together an cut the long ones once it's in place The long bolts will be the same distance from the ground, just with more thread exposed. Hey Trick213 - try putting threads like this in the upper north island section from now on and try to limit the number of new threads you start please. Quote
Truenotch Posted September 8, 2013 Posted September 8, 2013 The axle tube isn't going to change height Nigel. And he's talking about flipping the leaves back to the normal orientation, not removing the blocks. 1 Quote
Trick213 Posted September 8, 2013 Author Posted September 8, 2013 cheers guys! i guess your right nigel, im not the most mechanically inclined person which is why i joined this site to get some tips 1 Quote
