Matteybean Posted August 5, 2013 Share Posted August 5, 2013 Hi I have a question for you all. I currently have a rt104 corona with choppies have brought some new shocks and going to get some custom springs made but getting them made to an accurate ride height will be difficult with my chop ones so I'm wondering f anyone knows the standard ride height for an rt104 corona 1978 under load and after the measure which is top of the spring to the bottom of the spring under load and measure from bottom sil to the ground It's a long shot but worth a try !! Thanks Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 5, 2013 Share Posted August 5, 2013 If you get the installed height of your current cut springs and then drop them off at a spring place they should be able to sort it out for you. Quote Link to comment Share on other sites More sharing options...
Matteybean Posted August 5, 2013 Author Share Posted August 5, 2013 Yeah i didn't want to use my choppie height as its like 50mm off ground n wouldn't be accurate. If I can sus those measurements I will get some made I suppose even low or super low springs will do the same jus need those measurements Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted August 6, 2013 Share Posted August 6, 2013 he means the spring shop can do maths and work out what the springs should have been Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted August 6, 2013 Share Posted August 6, 2013 i think, maybe not though. but they can also work out the maths for your desired height im sure Quote Link to comment Share on other sites More sharing options...
Matteybean Posted August 6, 2013 Author Share Posted August 6, 2013 Yeah that's what I'm meaning but need a legit height first either lowering springs or standard height to give accurate measurements to spring shop Quote Link to comment Share on other sites More sharing options...
dave Posted August 7, 2013 Share Posted August 7, 2013 those springs had 4 coils chopped off bro. you can buy the lowering springs out off my gold one if you want(sits crossmember 100mm of ground on 15s) text me if you wanna sus it out Quote Link to comment Share on other sites More sharing options...
