will i am Posted December 27, 2012 Share Posted December 27, 2012 putting a starion motor and box into my ex lancer have a driveshaft that came off a sigma that had the starion motor/box in it (starion yoke) also have the original ex lancer driveshaft figured if i change the yoke over it would be straight forward problem i have run into is the starion yoke is wider than the lancer one i have thought off a few ways to get around my problem 1 find a universal joint to suit 2 shorten the sigma driveshaft to suit (approx 100mm to long) has anyone else run into this problem? or have a solution thanks Quote Link to comment Share on other sites More sharing options...
shizzl Posted December 27, 2012 Share Posted December 27, 2012 you can get ujs that are wider on one of the crosses... we use them at work all the time, my tech terms got left at work... but basically it would fit the one small to one large.. take the driveshaft and the yoke you wanna use to a driveline shop and see if they have an off the shelf uj thatll work. if not it would be easier to shorten the drivehsaft.. Quote Link to comment Share on other sites More sharing options...
will i am Posted December 28, 2012 Author Share Posted December 28, 2012 gave repco a try with measurements for universal joint that i would need came back with a no go so managed to track down the correct size yoke i need 1 problem down, 20 to go Quote Link to comment Share on other sites More sharing options...
evil_si Posted December 29, 2012 Share Posted December 29, 2012 Uj's with differnt leg lengths are a bit more specialised than repco The likes of beattys or adl would have been the go Quote Link to comment Share on other sites More sharing options...
shizzl Posted December 29, 2012 Share Posted December 29, 2012 asking for a sparkplug is a bit too specialised for repco 1 Quote Link to comment Share on other sites More sharing options...
will i am Posted December 29, 2012 Author Share Posted December 29, 2012 depends who you get at repco. when we order parts at work we avoid talking to some muppets on the other end funny enough i use to be a muppet on the other end getting abuse from the trade at repco good times lol Quote Link to comment Share on other sites More sharing options...
yeah yeah na Posted December 29, 2012 Share Posted December 29, 2012 +1 for atl, i have used them a heap, given the correct information they wont let you down. Quote Link to comment Share on other sites More sharing options...
FreePhase Posted January 15, 2013 Share Posted January 15, 2013 Hey man, whats the yoke ur using off? Quote Link to comment Share on other sites More sharing options...
will i am Posted January 16, 2013 Author Share Posted January 16, 2013 its of a gsr ex lancer Quote Link to comment Share on other sites More sharing options...
NVIOUS Posted January 24, 2013 Share Posted January 24, 2013 I used the drive shaft yolk off an old l200 ute that was at pick a part and it fit perfectly into the starion box an on to the 1600 lancer drive shaft 1 Quote Link to comment Share on other sites More sharing options...
