ta63-1uzze Posted August 6, 2012 Share Posted August 6, 2012 Hey guys, am plumbing up my steering, and I have run into a bit of trouble. When i bought it all i didn’t get to remove it from the car.( carina ta63 3tgte . ) So i am unsure what ports are what. And because I am not running a factory engine I can’t figure out how it may have been plumbed. I need to know what port on the rack is the high pressure in (from the pump) And what port on the rack is the low pressure out (to the cooler). There is one port on the head of the rack that is pointing towards the firewall , and one that is pointing to the side of the chassis, if that is of any help to identify them. Quote Link to comment Share on other sites More sharing options...
sheepers Posted August 6, 2012 Share Posted August 6, 2012 if one takes a bigger thread diameter fitting then thats the feed. usually the return has a smaller thread on the fitting. if not then maybe google some images of the car it came out of? sounds stupid but its worked for me in the past. Quote Link to comment Share on other sites More sharing options...
Simon Posted August 6, 2012 Share Posted August 6, 2012 If you connect them wrong you won't so any damage. It might squirt oil into places it shouldn't but I can't imagine is destroying anything. Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted August 6, 2012 Author Share Posted August 6, 2012 am scouring over goolge at present, found many pictures but nothing that I can make out what hose is what all i have is stubs of pipe i don’t even have a running car yet , i am just trying to fit out everything, cause the exhaust is next but i need to plumb up the steering so i know how much room i have around the knuckle and hoses. Guess I should stop being lazy and just strip it down. Quote Link to comment Share on other sites More sharing options...
Bling Posted August 6, 2012 Share Posted August 6, 2012 Tried toyodiy.com? Could be worth a shot Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted August 7, 2012 Author Share Posted August 7, 2012 Tried toyodiy.com? Could be worth a shot OH MY GOD !!!!! that site is freeking sweet!! the side one is the feed in and the back one is the low pressure out : ) Quote Link to comment Share on other sites More sharing options...
