low_mk2_escort Posted July 11, 2012 Share Posted July 11, 2012 ok heres the issue have a mk2 escort with a 2ltr in it it has had one of those magnetic pointless setups put in it . it winds over really slowly in the mornings and usualy needs roll starting where it will then run fine and be able to be turned off and started instantly so question is is the starter not winding it over fast enough or is the fuel pump shot runs nicely and good as gold till its left over night and requires starting in the morning the batterys a rather large new one 530 cold cranking amps have tried cleaning out carb with no fixed result seems to fire up ok with that engine start spray any input would be great cheers Quote Link to comment Share on other sites More sharing options...
tim13 Posted July 11, 2012 Share Posted July 11, 2012 had a similar problem with my old mk2 was starter in my case but battery terminals and battery le ads can give that sort of symptom , you can use jumperleads to bypass battery leads to help eliminate those quickly , hope it is an easy find/fix Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 11, 2012 Share Posted July 11, 2012 the choke in the cortina is being a penis and not working...requires lots of cranking and alot of pedal pumps,when it fires its mint.. has yours got the auto choke? Quote Link to comment Share on other sites More sharing options...
sholdowa Posted July 12, 2012 Share Posted July 12, 2012 Had the same problem over winter with one of the RS2's in my avatar. It was only when I burned the starter out that I found the 12V feed for the coil had fallen off. Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 12, 2012 Share Posted July 12, 2012 if its winding over really slowly id be looking at the battery. could be fucked, could be bad earths or something Quote Link to comment Share on other sites More sharing options...
low_mk2_escort Posted July 16, 2012 Author Share Posted July 16, 2012 ended up so far so good to be earth point for battery as its in the boot the earth was corroded both ends may have fixed its starting issue touch wood Quote Link to comment Share on other sites More sharing options...
