Grannyspec Posted May 30, 2012 Share Posted May 30, 2012 I Changed the auto gearbox is the girlfriends car the old why was slipping in drive and had to semi drive it like a manual going from 1 - 2 then to D to function. So got a new gearbox installed it, The new gearbox is doing the same thing. Any idea why this might be happening is it a dud gearbox or is it something else causing this fault? Cars a 1994 toyota Corona. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted May 30, 2012 Share Posted May 30, 2012 is there any fluid in the gearbox? Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted May 30, 2012 Share Posted May 30, 2012 is there any fluid in the gearbox? Hmm that is where I would start. Had an old commodore that used to do this when it was low of trans fluid. Quote Link to comment Share on other sites More sharing options...
Grannyspec Posted May 30, 2012 Author Share Posted May 30, 2012 I put about 5-6 Litres in there and it was reading full hot. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted May 30, 2012 Share Posted May 30, 2012 are the symptoms exactly the same between gearboxes? Quote Link to comment Share on other sites More sharing options...
Grannyspec Posted May 30, 2012 Author Share Posted May 30, 2012 Yes exactly the same Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted May 30, 2012 Share Posted May 30, 2012 did you use the same torque converter?? Quote Link to comment Share on other sites More sharing options...
Grannyspec Posted May 30, 2012 Author Share Posted May 30, 2012 No Different Torque converter. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted May 31, 2012 Share Posted May 31, 2012 Electronic issue? Quote Link to comment Share on other sites More sharing options...
Grannyspec Posted May 31, 2012 Author Share Posted May 31, 2012 Yeah thats what im thinking may have to hook it up to a computer and see what comes up, so brought a new gearbox for no reason. Quote Link to comment Share on other sites More sharing options...
