bigfoot Posted February 24, 2012 Share Posted February 24, 2012 I am considering buying thisthis for my lancer (1979 lb)as it currently has a welded diff (8 bolts around the diff head) My question is, will the diff head/axles/brakes fit onto my current diff housing (leaf spring) or is it not worth the effort Quote Link to comment Share on other sites More sharing options...
fuel Posted February 24, 2012 Share Posted February 24, 2012 sorry man I'm not sure. It looks to be the same disc brake diff found in non-turbo Starions or import RWD early 80s Sigmas. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted February 24, 2012 Share Posted February 24, 2012 sorry man I'm not sure. It looks to be the same disc brake diff found in non-turbo Starions or import RWD early 80s Sigmas. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted February 24, 2012 Author Share Posted February 24, 2012 hmmmm, might buy it and try and if it doesn't work i will sell it on. Are 8 bolt diffs all interchangable? this would be so much easier if my mitsi wasn't leaf spring Quote Link to comment Share on other sites More sharing options...
DiRtYnIgMa Posted February 24, 2012 Share Posted February 24, 2012 id be buying it up you could always sell it on easy enough. axels should be the same between them. diff head should be the same aswell. dont think there was much difference. its not hard to wack the mounts off and change. or you could possibly swap the stuff over into the other housing out of the lancer Quote Link to comment Share on other sites More sharing options...
bigfoot Posted February 24, 2012 Author Share Posted February 24, 2012 yeah, i think i will buy it anyway and deal with it later if it doesn' Quote Link to comment Share on other sites More sharing options...
DiRtYnIgMa Posted February 24, 2012 Share Posted February 24, 2012 if you can get it cheap it would be worth it. someone might need one. i dont have a use for it dont have a mitsubishi at the moment but its one of those things to jam in the shed somewhere and sell it at a later date or use it Quote Link to comment Share on other sites More sharing options...
