datto 260c questions
Shandangles
Hey all im considering buying this sweet as 76 datto 260c, but i have a question regarding wheel size and offset fitment.
Does anyone know the widest wheel and lowest offset that will fit before guards needs to be fucked with?
im thinking slammed 15x 8, 9 or 10 4wd spec steelies, but obviously cant try wheels before i buy the car
oh car in question is this bad boy, AC electric windows & PS.
I'll let you know in a short while, although mine's a 230 shape (like Zeb's) and yours is a 330 shape so there might be a difference?
CUL8R had 15x8 negative offset steels on his 330 Gloria (basically same chassis) so it may pay to ask him what the specs were.
15x8's with 0p will definitely fit, much more with a normal tyre and you'll rub, +p offset will be fine, theres heaps of backspacing.
I had my wheels offset changed, so was probably more like a -20 offset, and I had to pump the guards, with a 205 stretched.. Not an easy task pumping the guards, all double skinned
