Seedy Al Posted January 29, 2012 Share Posted January 29, 2012 Hey guys, Have a van in here at work, and thought I would chuck this out here to see what poeple think its a 1987 Town ace with a 3y-eu motor (yuck I know!!) What its doing is when you go to take off in haste it dies, then you have to go throttle open to get it to start again, Pretty much like its running rich, I suspect its either the TPS, or the Map sensor. At this point I'm heading toward map sensor. The check engine light doesnt come on or anything, so I dont know if its worth trying to find the diagnoistic plug to bridge the pins and find out what the deal is.?? What do ya'll think it could be? i dont like asking around as a mechanic I SHOULD know these things, but I'm not the best when it comes to these older style fuel injection sustems haha Hearts and kisses Quote Link to comment Share on other sites More sharing options...
crispy86 Posted January 29, 2012 Share Posted January 29, 2012 It could be gummed up in the throttle body itself, maybe the t.p.s could be at fault also. Have you checked the values of the t.p.s with mulitmeter? Like it idles fine if you start it but don't drive anywhere??? Also maybe clogged fuel filter?? I'd suggest checking the basic stuff first like fuel delivery, spark etc ect Quote Link to comment Share on other sites More sharing options...
Yowzer Posted January 30, 2012 Share Posted January 30, 2012 I thought 3Ys did that from new? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 31, 2012 Author Share Posted January 31, 2012 Checked the TPS, was working mint, Removed the PCV valve and cleaned the shit out of it, was pretty much not working at all And also set the timing up a bit better. Seems ok, hopefully thats te end of it, has made me an angry man haha Thnks for your helps Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 1, 2012 Share Posted February 1, 2012 Sounds like you sorted it yo For anyone who has a similar problem I'll chuck this up, basically get all the basics sorted before blaming/fucking with the ECU/sensors haha Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted February 1, 2012 Author Share Posted February 1, 2012 that is a good table! Quote Link to comment Share on other sites More sharing options...
