is there any other head that will fit a g62b
ex lancer wat!
yes 4G63 SOHC head from say a Starion would fit. Could perhaps even use a non-turbo head but make sure you get the blanking cover for the mechanical fuel pump and swap over the turbo cam. Later model MPI 4G63 SOHC heads have larger ports, as do the 4G64 SOHC heads.
Also next time can you post tech related posts in the tech section, not the general section? I have been moving your threads over but next time I'll just plain delete them.
