shizzl Posted November 2, 2011 Share Posted November 2, 2011 ok so i get lost with numbers and shit so need a bit of help from those who are onto it.. i need new rims for the ute so they dont stick out of the guards/deck so much.. if a 15x8 rim has 126mm from the hub face to the rear rim lip, what is the distance from the hub face to the front rim lip? 74mm?? anyone know if these will fit a courier? id go measure the distance from the hub face to the guard lip buts its been pissing down here for the last year(over exageration but its fucking wet) Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 2, 2011 Share Posted November 2, 2011 the 8" is the bead to bead measurement so the actual rim will be wider (maybe another 1/4) so say they are a total width of 8.25" = 209.55mm then subtract 126mm for the hubface in inner lip = 83.55mm so in theory there should be 83.55mm of rim sticking out from the hub. Quote Link to comment Share on other sites More sharing options...
mikuni Posted November 2, 2011 Share Posted November 2, 2011 From the info you've given us, it can't be worked out. 8 inches is only the measurement across where the bead sits, the overall width of the wheel from lip to lip will be more, usually about an inch overall. So, the distance from hub face to inner lip and hub face to outer lip will be greater than 8 inches, or 203mm. As a rough estimate, I'd say you have about 4 inches outer (101.6), 5 inches inner (127mm close to what you say) giving about 9 inches overall lip to lip and +25.4 offset. But just guessing. Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 2, 2011 Author Share Posted November 2, 2011 hmmm this is what they said on the auction.. Written on inside of wheel: T/8JJx15-1505 DOT 07/06 Made in Brazil 330 Measurement from inside of hub to inside of rim is 126mm. http://www.trademe.co.nz/Browse/Listing ... =419312142 Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted November 3, 2011 Share Posted November 3, 2011 google knows all; http://www.willtheyfit.com/ that should see you right. Quote Link to comment Share on other sites More sharing options...
