4age inlet manifold thickness
BS5620
For all of you that have cut and shut a 4age inlet manifold.
Can you remember how thick it was???????.
Got pulled up on my cert for the brake M/C hitting the manifold so want to file some meat off to give some clearance!!
Cheers
Last one I drilled through (accidently) was about 3 - 5mm max from memory, not thick at all. This was up the front on the side though, back end might be a bit thicker.
yeah this hits on the side at the back end so 3-5mm i think i wont touch it with a file!!
Having the flange milled down is a good idea but dont think it would remove enough!!
Probably have to add a spacer to 1 engine mount to to put engine on a lean!!!
Cheers
