igor Posted May 17, 2015 Share Posted May 17, 2015 you need these http://www.trademe.co.nz/motors/car-parts-accessories/wheels-tyres/tyres/auction-887228643.htm 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted January 12, 2019 Author Share Posted January 12, 2019 I found a branch in the long grass. Anyone got a Commodore radiator they don't want? Quote Link to comment Share on other sites More sharing options...
CarolsHusband Posted January 13, 2019 Share Posted January 13, 2019 On 15/10/2011 at 05:05, Nominal said: Nah, I like it though. Quote Link to comment Share on other sites More sharing options...
Nominal Posted January 12, 2020 Author Share Posted January 12, 2020 Engine has been running barely for the last couple of years. Suspect a blown headgasket by the way the water in the radiator would foam out. Anyway, liberated another VN V6 from a stalled CF Bedford project. Got around to swapping over the past few days and found that it's a Series 1, where the one I had in here before was a Series 2. So, I needed to swap the loom over as well. Had some hassles getting it to run again, probably because the injectors were a bit gummed up. Starts now though: Need to sort the radiator plumbing to convert to a VR radiator and bolt a few bits back into place. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 2, 2020 Author Share Posted May 2, 2020 Load testing 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Nominal Posted October 17, 2021 Author Popular Post Share Posted October 17, 2021 Had a couple of 33" (I think) wheels from @LV#5 brought up from ChCh by @BobbyBreeze (thanks!). I knew there were a few broken studs on the LHS. BNT wanted $26 each for correct L200 ones, but a set of 5 1/2" trailer studs with nuts was only $28 so on they went. One of the engine core plugs is rusted out and leaking a lot, so I suppose I should fix that one day. 14 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 12, 2021 Author Share Posted December 12, 2021 Has some mud traction now. 2 Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 18, 2023 Author Share Posted February 18, 2023 Still good for stress relief / paddock mowing 2 Quote Link to comment Share on other sites More sharing options...
Nominal Posted July 14, 2023 Author Share Posted July 14, 2023 I want to get shot of this, $1k maybe? 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 7, 2023 Author Share Posted August 7, 2023 Buh-bye! 8 Quote Link to comment Share on other sites More sharing options...
