drtydog Posted March 18, 2011 Share Posted March 18, 2011 so, installed second hand starter in my old ladys 87 merc 300e hooked it all up sweet as went to turn the key and i'm getting a great big spark off the main positive cable and no starting?!?!?! any ideas guys? never come across this b4 mayb something glaringly obvios and i've failed but i can't see anything i've installed wrong Quote Link to comment Share on other sites More sharing options...
Jase Posted March 18, 2011 Share Posted March 18, 2011 earth and hot wire mixed up inside the starter? Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 18, 2011 Share Posted March 18, 2011 shouldnt be any sparks at cables at all if everything is bolted on correctly. have you tested siad starter before you put it in?? . as jase siad new starter could be as pwnt as old one Quote Link to comment Share on other sites More sharing options...
R100 Posted March 18, 2011 Share Posted March 18, 2011 Make sure all your connections are real tight. Check the connections at the battery, if you can twist them with your hand there too loose. Conections to the startet should be tight aswell Quote Link to comment Share on other sites More sharing options...
drtydog Posted March 18, 2011 Author Share Posted March 18, 2011 all conections are tight and in the correct place i'm starting to think corosion inside the solonoid sound like a possibility? Quote Link to comment Share on other sites More sharing options...
R100 Posted March 18, 2011 Share Posted March 18, 2011 corosion in a slenoid would cause sparks like you described. Solenoids very rarely pack up anyway. Where are the sparks comming from? Will the engine crank over at all ? Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 18, 2011 Share Posted March 18, 2011 pull it back out and bench test it , pre enagage starter?? well even if it isnt every you need to check on a start can be done on the bench . Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 18, 2011 Share Posted March 18, 2011 tap the solenoid with a hammer Quote Link to comment Share on other sites More sharing options...
drtydog Posted March 18, 2011 Author Share Posted March 18, 2011 it sparks from the main positive cable that bolts to the solenoid, arcing onto the body of the starter, and no it doesn't crank one spark then nothing Quote Link to comment Share on other sites More sharing options...
R100 Posted March 18, 2011 Share Posted March 18, 2011 Tighten the battery cable to the starter. It will only spark if its loose. If its tight-no sparks Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 18, 2011 Share Posted March 18, 2011 as r100 says shit only sparks if its loose Quote Link to comment Share on other sites More sharing options...
drtydog Posted March 18, 2011 Author Share Posted March 18, 2011 well got the starter sorted was corosion on the positive solenoid lug so got the car all back togeather and going drove put into drive and noticed it missing slightly got 100m up the road and it stalled and won't start again just cranks....also noticed excessive white steam out exhaust so i give up tonight lol i'll push it home tomorow and have another look at it...anyone want a merc? Quote Link to comment Share on other sites More sharing options...
