that fucking bolt
barf
so I'm frustrated and want some advice.
trying to disassemble the oil pump on the 4G93 to de-coke it, the bolts are supposed to be torqued to 10NM but after 270,000kms they seem pretty stuck. they are a plus-head countersunk bolt and i'm not keen on mincing the bolt head if i can avoid it, theres no nut they just fasten into the oil pump. whos got the best pro-tips?
do i reaaaaalllly have to drill and eziout these tings? would heating/cooling help?
get a taper punch ground to a sharp point, one whack with a hammer on the outer edge between the "+" straight down to make a little "crater" then you should be able to use the punch and hammer on an angle to turn it. hard to describe without sounding retarded but it works well
quoted for the truth
