DriveBy Posted November 29, 2009 Share Posted November 29, 2009 Just replacing some bits of the fuel line on the starion and I need some flare nuts for 3/8" line and also some an-6 fittings for the braided section from hard line to pump. Where's the best place to buy these individually? Cheers Quote Link to comment Share on other sites More sharing options...
m0ss4yy Posted November 29, 2009 Share Posted November 29, 2009 you could try somewhere like mastertrade or an engineering shop? Quote Link to comment Share on other sites More sharing options...
crooked Posted November 29, 2009 Share Posted November 29, 2009 Look on trademe for your -6 an fittings, they are cheap as, iv used them before and they havnt failed for me, also can get braided line of trademe aswell for half of what you would get it anywhere else... Quote Link to comment Share on other sites More sharing options...
DriveBy Posted December 1, 2009 Author Share Posted December 1, 2009 Thanks guys. Quote Link to comment Share on other sites More sharing options...
OLDMAZ Posted December 2, 2009 Share Posted December 2, 2009 Check us out www.alertmotorsport.com Quote Link to comment Share on other sites More sharing options...
Unclejake Posted December 2, 2009 Share Posted December 2, 2009 ":263rlvif]Check us out http://www.alertmotorsport.com Interesting product list.How do the Aeroquip fluid fittings compare with Earls (they look pretty damn identical)? Do you guys do a match service - i.e. I send you various brass and steel fittings that are probably the american taper thread (is that NPT?) or BSP and you find and supply the equivilent in alloy? My problem is that I am terrible when it comes to identifying tapered threads but I have a bunch of fittings that are either brass or steel and they are too heavy so I want to replace them with alloy Quote Link to comment Share on other sites More sharing options...
OLDMAZ Posted December 2, 2009 Share Posted December 2, 2009 ":3nhq17d2]Check us out http://www.alertmotorsport.com Interesting product list.How do the Aeroquip fluid fittings compare with Earls (they look pretty damn identical)? Do you guys do a match service - i.e. I send you various brass and steel fittings that are probably the american taper thread (is that NPT?) or BSP and you find and supply the equivilent in alloy? My problem is that I am terrible when it comes to identifying tapered threads but I have a bunch of fittings that are either brass or steel and they are too heavy so I want to replace them with alloy NPT is National Pipe Thread which is worldwide and BSP is British Standard Thread which we aren't into in a huge way in terms of stocking those fittings. Quote Link to comment Share on other sites More sharing options...
Testament Posted December 3, 2009 Share Posted December 3, 2009 NPT = ewwwwww Quote Link to comment Share on other sites More sharing options...
jamespipers Posted September 3, 2010 Share Posted September 3, 2010 Internet is the best place to be. All you need to do is to search for your fuel line fittings. The net can perfectly provide you the size of fittings you most need. Quote Link to comment Share on other sites More sharing options...
