QCADTA Posted October 14, 2009 Share Posted October 14, 2009 i might just try find all the measurements for as any as i can see if any of them measure up close to the escort one. And ultimately if that fail then i'll resort back to hilux one, with them is it jus shortened that needs doing or is there more involved in the process? read the tech articles on hilux diff into escort. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 14, 2009 Share Posted October 14, 2009 ^^ What he said. Plus what power you runnng? Gaz Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 14, 2009 Share Posted October 14, 2009 There's an anglia race car that runs an SR20DET and a ford diff.... 300HP through an Anglia diff with quaife centre and custom axles. Strong custom made chrome-moly axles are reasonably priced from Mr Howat in Wellington. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 19, 2009 Share Posted October 19, 2009 I have said that you will not blow a standard diff with a Pinto unless you treat it badly but if you are serious about upgrading then bid here http://www.trademe.co.nz/Trade-Me-Motor ... 644798.htm This is not an ideal street ratio. Truenotch - who is Mr Howatt? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 19, 2009 Share Posted October 19, 2009 ^^ Brian Howat in Nae Nae, Gaz has had a bit of work done by him and I'm getting axles done there at the moment. Seems like a good dude and does a lot of work for 4WD club. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 19, 2009 Share Posted October 19, 2009 Chur boe. I will store that in the memory banks. An associate had some Quaife floating axles and bearings on the market for the Cortina a while back but I could not imagine that I needed them. If I get stronger axles the diff will be the next thing to break. The main attraction in the floating axles is the possibility of adding a touch of negative camber with less stress and the added safety associated with a captive wheel if the axle does fail. A chap I know got clogged in the stands by a flying Mustang wheel at Taupo a few years ago (I was there but not involved) after an axle broke post collision. Scary shit. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 20, 2009 Share Posted October 20, 2009 Chur boe.A chap I know got clogged in the stands by a flying Mustang wheel at Taupo a few years ago (I was there but not involved) after an axle broke post collision. Scary shit. That is scary! I love my floating axles.... especially when a crownwheel/pinion dies and seizes - pop axles out and push on the trailer. Easy. Quote Link to comment Share on other sites More sharing options...
RT Posted October 20, 2009 Share Posted October 20, 2009 Baby Atlas Diff from a Mk1 3L Capri Good for 200 odd hp which is more than you'll 2L be making. Fit straight in, has brackets for anti-tramp bars, same stud pattern for your wheels, big 3L drum brakes. I happen to have one for sale soon if you're interested. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 20, 2009 Share Posted October 20, 2009 RT, do you have any way to weigh that complete drum to drum axle assembly once it is removed? What year did that diff housing come out? The date of internals don't matter, just the housing. I would be ever so grateful.............. Quote Link to comment Share on other sites More sharing options...
RT Posted October 20, 2009 Share Posted October 20, 2009 guess I could see if someones got a few scales I could put one under each side and total the weight. Don't know about year, it's out of a V6 MK1 Capri so will be between 1969-73 If the 3.22 doesn't suit then you can swap crown wheels from any atlas ie. a 3.54 or 3.77 from a 2L capri. But only the V6 MK1 had the narrow atlas that all the escort boys want. About 2" shorter than a standard Atlas. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 20, 2009 Share Posted October 20, 2009 I didn't know about these diffs. Are after market cw&p available in lower ratios (like 4.5:1)? http://www.vkukko.fi/ford/atlas.htm Quote Link to comment Share on other sites More sharing options...
RT Posted October 20, 2009 Share Posted October 20, 2009 sure, people have been racing atlas diffs for years all the standard aftermarket parts are avail. LSD's etc. But pretty expensive for a new LSD unit unless you manage to score one out of a 2.8i S Capri but good luck finding one of those. I know one person who has one in his garage but he won't sell. lol http://www.palmside.co.nz/parts.asp?mak ... egory=DIFF Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 20, 2009 Share Posted October 20, 2009 LSD bad. Open diff good. Pre65.org.nz Quote Link to comment Share on other sites More sharing options...
super_gt Posted November 27, 2009 Share Posted November 27, 2009 just wondering if there are any worthwhile ways to strengthen the diff? i've heard you can shorten the hilux diffs and have them put in there, but i've also heard that's pretty expensive and that it needs quite a bit of work. Are there any other ways to make the diff slightly stronger? bro ive got an rn25 hilux and a mk2 esky in my shed there is exactly 5mm difference in diff width hilux is 5mm shorter Quote Link to comment Share on other sites More sharing options...
Sorensin Posted November 27, 2009 Share Posted November 27, 2009 you should totaly sell me the diff from your hilux. Cheers Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 27, 2009 Share Posted November 27, 2009 just wondering if there are any worthwhile ways to strengthen the diff? i've heard you can shorten the hilux diffs and have them put in there, but i've also heard that's pretty expensive and that it needs quite a bit of work. Are there any other ways to make the diff slightly stronger? bro ive got an rn25 hilux and a mk2 esky in my shed there is exactly 5mm difference in diff width hilux is 5mm shorter ONLY on the RN25 (rare as rocking horse shit) and early hilix diffs. The later (more common) model diffs are way wider. Gaz Quote Link to comment Share on other sites More sharing options...
super_gt Posted November 30, 2009 Share Posted November 30, 2009 you should totaly sell me the diff from your hilux.Cheers haha, maybe one day, im not satisfied with my attempts to break it yet gaz is right there arent many around, i do know where a complete ute is, its stuffed but if you only want the diff it could be good Quote Link to comment Share on other sites More sharing options...
Sorensin Posted December 1, 2009 Share Posted December 1, 2009 yea pretty keen... is it in aux? Quote Link to comment Share on other sites More sharing options...
super_gt Posted December 3, 2009 Share Posted December 3, 2009 yea pretty keen... is it in aux? um na...its in wellington lol Quote Link to comment Share on other sites More sharing options...
