plasticdash Posted September 1, 2009 Share Posted September 1, 2009 I have searched this forum and the internet for the torque settings for bolts that hold 3 piece wheels together and have got a wide variety of answers. 12.9 cap screws in 8mm x 1.25 pitch and 13mm nut on back. qty 20 fasteners per wheel - simmons v4's Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 1, 2009 Share Posted September 1, 2009 viewtopic.php?f=48&t=14501 Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 1, 2009 Share Posted September 1, 2009 What he said. I did mine to 30nm I think. They still holding the rim together too. Gaz Quote Link to comment Share on other sites More sharing options...
plasticdash Posted September 1, 2009 Author Share Posted September 1, 2009 thanks ! just been cleaning the rims and pulled the centre out to autosol the shiny bits - they had at least 5 years of brake dust on the inside one down, three to go Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 2, 2009 Share Posted September 2, 2009 Looks good. You may have sealing problems when you pump the tyre back up now? Quote Link to comment Share on other sites More sharing options...
Simon Posted September 2, 2009 Share Posted September 2, 2009 Looks good. You may have sealing problems when you pump the tyre back up now? more sillycoan. I run tubes in my 3 pieces. Is mint cos i just split them to get tyres on / off. Quote Link to comment Share on other sites More sharing options...
Testament Posted September 4, 2009 Share Posted September 4, 2009 probably not a bad idea to use loctite on the nuts either Quote Link to comment Share on other sites More sharing options...
plasticdash Posted September 4, 2009 Author Share Posted September 4, 2009 Looks good. You may have sealing problems when you pump the tyre back up now? should be good to re-inflate. only took the centre out, didnt seperate the two rim halves. (time will tell thou) probably not a bad idea to use loctite on the nuts either yes, will apply lashings of loctite 222 when i torque them up Quote Link to comment Share on other sites More sharing options...
Simon Posted September 4, 2009 Share Posted September 4, 2009 Personally i wouldnt bother with loctite When i did theses wheels I just did them up to the torque i though suitable and that was that. I checked them again after about 5000k and they were still the same. They are only 2 piece, but im not sure it would matter. If i had a wheel like ssr mk2 with only a few bolts holding it together i would probably use loctite but for your wheels it would just make it a PITA when you want to split them again if they leak. Quote Link to comment Share on other sites More sharing options...
plasticdash Posted September 4, 2009 Author Share Posted September 4, 2009 Loctite 222 is low strength suitable for small bolts so will be ok to take apart, I wouldn't go putting 272 or 277 on them ! thats for sure. Quote Link to comment Share on other sites More sharing options...
