Sorensin Posted March 26, 2009 Share Posted March 26, 2009 Hey guys anyone know anything about this? Saw this add on TM and very interested to know more baout conveting my 1600 to a 1800 http://www.trademe.co.nz/Browse/Listing.aspx?id=209016628 Thanks Guys Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2009 Share Posted March 26, 2009 It is standard bore and those liners are too small to take it to 1800cc without stroking it with a Datsun crank etc. 85mm bore is 1800cc with a stock crank & rods so the liners would have to be over 88mm. Quote Link to comment Share on other sites More sharing options...
escorted Posted March 26, 2009 Share Posted March 26, 2009 Would it hold together long? How close to the water jacket? Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2009 Share Posted March 26, 2009 Would it hold together long? How close to the water jacket? That block wouldn't even take the 85mm bore, the liners are about 85mm external diameter, its prepped for Formula ford where they can't go more than 0.010" over (I think its 0.010"). If done right with a good block you should have no problems but good luck finding a block that will take that bore (Fords quality control wasn't too flash back then and you will find some blocks with off center bores and all sorts of prob's -took a long time to find a decent block for my old 83.5mm bore) The best way to do it is to have a block lined specifically to take the 85mm bore then stroke it with the steel crank etc. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted March 26, 2009 Share Posted March 26, 2009 The best way to do it is to have a block lined specifically to take the 85mm bore then stroke it with the steel crank etc. Been there, done that, spent the $6k on the bare block and it still pegged out due to insufficient support behind the flowcast wetliners (sleeves) but that was on a pre-crossflow which are a bit thinner Personally I won't be going past 84mm and my new motor is 83mm (if it ever gets finished) Quote Link to comment Share on other sites More sharing options...
Sorensin Posted March 26, 2009 Author Share Posted March 26, 2009 Stroking it is what i wanted to know more about but spoke to a couple ppl on the phone sounds like a real expensive way to go, ill just stick my original plans of 60thou over on standard crank. Thanks guys Quote Link to comment Share on other sites More sharing options...
sholdowa Posted March 26, 2009 Share Posted March 26, 2009 You need an AX block to even attempt to go that big. There's a few left in South Africa apparently, but they're pretty expensive. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2009 Share Posted March 26, 2009 You need an AX block to even attempt to go that big. There's a few left in South Africa apparently, but they're pretty expensive. With a stock crank you can do it with liners, I think Slipsitting had at least one block with an 85mm bore. It can be also be done with a 711 block using Datsun crank etc but with the machining involved its not a cheap build. Quote Link to comment Share on other sites More sharing options...
Sorensin Posted March 26, 2009 Author Share Posted March 26, 2009 Yea I wanted to know about using the datsun crank but I have spoken to a couple people and its not a cheap thing to do so I'll give it a pass. Quote Link to comment Share on other sites More sharing options...
