penco Posted November 27, 2008 Share Posted November 27, 2008 ive got a kp-61, 4k engine, no mods at all, stock standard. It happens every time i take it for a drive if it hasnt be driven for more hten afew hours. I will turn on the car and drive, the car will slowly get hotter and hoter until its about 5mm from going into red on the gague, then it will ALWAYS drop down and stay at a normal temperature the rest of the ride. i have checked all my liquids and they are all topped up. Any ideas? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted November 28, 2008 Share Posted November 28, 2008 It is your thermostat opening. You may wish to replace it Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted November 28, 2008 Share Posted November 28, 2008 sounds like your thermostate is playing up... just replace it there only like $10 Quote Link to comment Share on other sites More sharing options...
reTRD Posted December 1, 2008 Share Posted December 1, 2008 i to say it the thermo, after replacing that if it still does it just disconect the top plug that goes into the neck of the thermo housing and this will make your fan run full time. it worked in my kp and now it never gets hot like it use to and i got a worked 5k in it with a standard 2k radiator Quote Link to comment Share on other sites More sharing options...
Alistair Posted December 1, 2008 Share Posted December 1, 2008 I had to do this to my 5k kp61 at the drags. Pop that plug off so fan is going all the time. Only happened sitting for long periods of time. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted December 2, 2008 Share Posted December 2, 2008 The 5K in my van was doing the same thing, sounds weird, but it was the belt slipping, front main seal was leaking a bit, would fling oil onto belt and slip, making the engine get hotter, then after a while the belt would start gripping again and temp would come back down. If you go for a bit of a frash, and rev it a bit, dose the temp rise up fairly quickly? Quote Link to comment Share on other sites More sharing options...
