Raizer Posted November 25, 2008 Share Posted November 25, 2008 If I'm right(probably not) the holes have to be drilled out. Its easier just to run a Xflow pressure plate with the Hillman disk though, or have the Xflow flywheel redrilled to take the full 2L clutch set up. Quote Link to comment Share on other sites More sharing options...
RoddyB Posted December 8, 2008 Author Share Posted December 8, 2008 IT LIVES!! thanks for the help guys. problem turned out to be a combination of faulty dizzy (initial problem) and tired carb. I put the five speed in too. Just in time to leave chch and drive the hundreds of ks north. it was a rushed but fun mission. Representing the winterless far north now. anyone from north of whangarei? swapped flywheel, clutch and gearbox from sierra so it would all fit. got cortina drive shaft modified at circle track engineering. in the end it all came together pretty well considering i had no idea what i was doing. ended up just using a piece of steel channel for the crossmember with the rubber mount fitted in there too. works mint except that the exhaust now needs a hammering so it doesn't rattle on it at idle! car is running on a bit when it's hot but have been filling with 91 so will try something higher to see if it cures it. heard that could be an easy fix. Quote Link to comment Share on other sites More sharing options...
slipsittin Posted December 8, 2008 Share Posted December 8, 2008 Yeah I wouldn't run 91 in it unless you have a good timing light to set it up for it. Awsome to hear it is going again. Corey Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted December 8, 2008 Share Posted December 8, 2008 anyone from north of whangarei? Whereabout are you man? Quote Link to comment Share on other sites More sharing options...
RoddyB Posted December 9, 2008 Author Share Posted December 9, 2008 Just near Waipapa. You? Quote Link to comment Share on other sites More sharing options...
Jase Posted December 9, 2008 Share Posted December 9, 2008 ol man lives in hikurangi but we lived in mangonui for eight years, live in hams now Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted December 9, 2008 Share Posted December 9, 2008 Just near Waipapa. You? Living in whangarei Quote Link to comment Share on other sites More sharing options...
