mixmasterlex Posted October 21, 2008 Share Posted October 21, 2008 Pulled the plugs out of the 3t-gte, cleaned them all then got to the last plug. came out no problems, but trying to get it back in, it does about a full turn then is really hard to screw in, I don't want to force it as im scared ill thread something. Anyone got any tips for getting plugs in easy? Or is it possible I have threaded the spark plug cylinder? thingy... or? Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted October 21, 2008 Share Posted October 21, 2008 sounds like its cross-threaded there boe..... Quote Link to comment Share on other sites More sharing options...
Requiemk Posted October 21, 2008 Share Posted October 21, 2008 put a lil oil on it if you dont got any copper coat and try gently turn it and see if you can catch the threaded again. If it came to running a tap through would putting grease on it be safe enough to prevent metal flakes falling in? Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted October 21, 2008 Share Posted October 21, 2008 Should be. did exactly that on Falcon race engine. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 21, 2008 Share Posted October 21, 2008 Cowboy way - get an old spark plug cut some diagonal cuts 45 degrees(ish) across the thread with a hacksaw (about 2mm deep) coat the spark plug in grease - getting some into the grooves you cut wind the plug in gently - making sure it is going in super straight wind in 1 turn back off half turn - wind in one turn back off half a turn etc until you are about 4 turns in remove plug and clean off swarf - recoat in grease and carry on etc etc tis a workzor - if it an old snotter motor I wouldnt be overly freaking out about shit falling in the combustion chamber - combustion heat should melt and spit that shit out real fast. If you too scared to do this - get an engine reconditoner to bring round his tools and get him to do it - he would most probably have a proper tap and experience etc Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted October 21, 2008 Author Share Posted October 21, 2008 piss... don't really want to get brokeback on this.. Will see if my mate has sparkplug tap taps. Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted October 22, 2008 Author Share Posted October 22, 2008 so went home and put a bit of oil on the thread and managed to get it in. Was harder to get in than the rest but seemed to go in ok.... Now the car is blowing a fair bit of blue, it shouldn't take long for it to burn off any oil that might have dripped into the head... Sort of blue under boost, blue when revs held highish, and more white smoke when you come off the gas after some boost.. Does that sound like it could be the H/G? Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted October 22, 2008 Share Posted October 22, 2008 Not sucking brake fluid in anywhere??? Or pressurising radiator? Or excessively fumey? Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted October 22, 2008 Author Share Posted October 22, 2008 Not sucking brake fluid in anywhere??? Or pressurising radiator? Or excessively fumey? Brake fluid? Don't think so.. Pressurising radiator? Maybe... How should I check? Its no using any coolant or anything.. Fumes... Yes... I like my 80's turbo cars running rich mother fucker! But for real.. im not sure. It smells, but im guessing thats the smell of delicious blue smoke. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted October 22, 2008 Share Posted October 22, 2008 take cap of radiator and start the car. if the h/g is blown there will be a constant stream of bubbles coming up. Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted October 22, 2008 Share Posted October 22, 2008 Not sucking brake fluid in anywhere??? Yeah it sounds silly but, Fluid can bypass the brake booster if its faulty while under vaccuum (ie lifting off) and brake fluid produces white smoke. Sounds like effed rings to me honestly if its fumey as, ie allowing compression into the sump which pushes oil up the bores past the rings creating your wonderful blue haze.... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 22, 2008 Share Posted October 22, 2008 you possibly jumping to conclusions - the white smoke could be condensation - If you are loosing water or the cooling system has mega pressure I would start to worry about blown head gasket - the only true way to check for a blown headgasket is a compression test/cylinder leakage test - a fairly safe and easy way is with a TK head check most garages will have a TK check - as long as the fluid has not gone off it should be pretty accurate. Quote Link to comment Share on other sites More sharing options...
