chur Posted November 2, 2008 Author Share Posted November 2, 2008 That engine looks nice in there Cheers mate. Its given me a lil more motivation with it sitting in the all bolted up lol. Quote Link to comment Share on other sites More sharing options...
Toucan Posted January 13, 2009 Share Posted January 13, 2009 YUM! Thats so tidy. I hope you can keep the engine bay that clean looking, looks so so sweet More updates please! Quote Link to comment Share on other sites More sharing options...
chur Posted January 14, 2009 Author Share Posted January 14, 2009 Thanks. Hahaha yeh me too lol. will just have to see when she is on da road. Yeh man ill keep you post as the build goes on. Just getting the body ready for paint but im not to sure on weather to go for a matte or gloss finish. Matte body probably match the gloss engine bay. I duno can any one help me out? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted January 14, 2009 Share Posted January 14, 2009 No question, gloss for sure bro. Looks really good in there Quote Link to comment Share on other sites More sharing options...
treggo Posted January 14, 2009 Share Posted January 14, 2009 Gloss Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 14, 2009 Share Posted January 14, 2009 hey look like im not alone on this venture then if you plan on doing the starion brake up grade its a fair bit more work than i i thought it was you have 2 options the starion springs are too wide for the lancer strut towers so..... 1. (the way im doing it) the lancer struts need to be ''un-welded'' from the hubs (i cut through the hub just above the weld) then the starion struts need to be cut of at the top of the hub and a spacer made to shim the difference out, then weld the lancer strut into the starion hub im getting a certified welder to do the welding just incase i come into any doubts from the cert guy you can then use the lancer springs and its all hokey pokey 2.(the easy way but im an awkward cunt) convert the starion struts to the generic coil over kits wow wasn't that one hard i had already payed for the lancer springs when i started the conversion so No.1 was cheaper for me either way just bolt the ball joint from the lower arm into the bottom of the starion hub and your away Note: the starion hub has a longer steering arm bracket thing im not sure how this affects the car yet i haven't got that far Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 14, 2009 Share Posted January 14, 2009 oh and if you buy some starion struts i have some brand new gas gt inserts for them Quote Link to comment Share on other sites More sharing options...
chur Posted January 14, 2009 Author Share Posted January 14, 2009 hey look like im not alone on this venture thenif you plan on doing the starion brake up grade its a fair bit more work than i i thought it was you have 2 options the starion springs are too wide for the lancer strut towers so..... 1. (the way im doing it) the lancer struts need to be ''un-welded'' from the hubs (i cut through the hub just above the weld) then the starion struts need to be cut of at the top of the hub and a spacer made to shim the difference out, then weld the lancer strut into the starion hub im getting a certified welder to do the welding just incase i come into any doubts from the cert guy you can then use the lancer springs and its all hokey pokey 2.(the easy way but im an awkward cunt) convert the starion struts to the generic coil over kits wow wasn't that one hard i had already payed for the lancer springs when i started the conversion so No.1 was cheaper for me either way just bolt the ball joint from the lower arm into the bottom of the starion hub and your away Note: the starion hub has a longer steering arm bracket thing im not sure how this affects the car yet i haven't got that far Cheers for that man. Didnt think id see another lancer around like mine lol. I was gona try put some vr4 brakes on my lancer. Mite look at the starion conversion tho alot of people some to do it on there ex lancers. You wouldnt happen to have any spare parts you would sell? i really need a rear bumper and bonnet Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 15, 2009 Share Posted January 15, 2009 ive got a rear bumper but im using it you can have it once i find a nicer looking gone to fit on there, mine are the rubber capped ones and i want the full chrome ones are you after any other parts? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted January 15, 2009 Share Posted January 15, 2009 Look in the "technical how to" section down the bottom of the forum and find the mitsubishi thread. A user on here did the EX GSR strut swap, which are similar to Starion struts. From what I understand it's only the 1200cc models that have the narrower towers Edit: viewtopic.php?f=13&t=7862 Quote Link to comment Share on other sites More sharing options...
Low320 Posted August 19, 2011 Share Posted August 19, 2011 Im after a front passenger side gaurd for a 79 lancer if n e one could help me out? 0273859542 Quote Link to comment Share on other sites More sharing options...
infinite Posted August 20, 2011 Share Posted August 20, 2011 im runing complete sigma station wagon front struts, aparently rx7 4pots and disk's will go on with an adapter plate..... but atm i have Sigma wagon lower arms Standard Lancer tie rod ends/steering arms Sigma Struts with the lancer top hats.... seems to work fine! have also ground the steering stop blocks off the cast steering arm on the hub, mean drift lock but think im going to have to go back to some unground ones, will get a pick tomorrow... Quote Link to comment Share on other sites More sharing options...
