shizzl's NEW stock car.. *new pic* 28/12/09
shizzl
  • Replies 80
just thought id try to tap in to my redneck roots and race a stockcar for
a season or 2..
this one is powered by a EL falcon straight 6.
tagged in behind is a falcon box.
mazda diff and apparently mazda hubs..
will have the same ford Y body but of a uglier condition
but that doesnt matter due to it needing a paint anyway
just incase those mega million dollar sponsors wanna
see how beautifully maintained it is :lol:
its here....
picked it up from chch with a shit as broken arse body on it from an old superstock.
got it home,fibreglassed the holes and cracks.
sprayed it satin black
put gearbox back in..
fired it up,sounds hella evil...and loud from a supertrapp!!!
before:
after:
so ive been thinking alot about starting to build my own flat chassis...so ive done a shiz load of drawings,mostly to scale (1:20)..
i based it on the dimensions of my current chassis,but will end up changing it i guess.
but i drafted a plan onto paper to scale and decided to construct one out of some balsa wood i had.
the balsa isnt to scale though..the 5mm should be 75x75 in real form,the rollcage is way oversized,but you get the pont of what im thinking of anyway..
havent done anything in the way of a front end or diff,as yet...
havent decide if id go IRS or offset or keep it centred.
front i cant decide to stick to the 5 linked beam,or independent or with cantilever...
heaps of options,and all with their own pros and cons..
i personally prefer the flat chassis to the space frame as they come out better off in teams races and general furk them up racing..sure you feel the hits more,but ill be going for a cushy seat..
the plan is build the new chassis in winter and sell my current one as a roller..
looking for options for a jap gearbox instead of using a zf bedford box/hq box or landcruiser...theyr all getting hard to get and damn expensive..
well ive been offline recetly...
so a bit of an update...
30th dec i went down to cromwell for the xmas champs..
the stockcars were invited as a demo class.
there were 12 cars for the 30th,not bad seeing as there was a car from nelson,one from chch,mine from greymouth and the rest from dunedin and invergiggle..
I opted to start all 3 races off the back as it was only my 2nd meeting,and the 1st meeting
was only 3/4 of a race for me..so still newby..
cromwell is a furkn fast track if ya got the balls to stand on the gas..
i finished the first race being lapped by everyone....
2nd race i stood on it,ony got lapped by 3 cars,then the temps got up,
and heading into the pit gate the radiator hose split wide open and
dumped the entire contents on me,i smelt like coolant and ass for days..
fixed the hose for the 3rd race,and i didnt even get lapped..
fukn stoked with the progress..went over the line with the lead car
about 30m behind me 8):lol:
left the car there and returned on the 1st jan for the war of the wings meeting..
this time i went in the marble draw..1st race i was on pole..
greens on,hammer down,1st corner and taking hits like tyson,and the damn clutch pin breaks
out again,thats me for that race,did 2 turns,sat that one out.
2nd race was off the back being reverse grid in 2nd race.
6 laps in i started giving it death,going hard then got teams raced into the wall by
2 twins from dunedin,i basically did a victory lap on the wall,slammed back down and they
took off,i did another lap and the car felt weird as hell,then going down the back straight i see a spring lying on the track,it looked like mine....
then 2 slam,took to the wall again...
managed to drag its arse over the line to finish the race,but it bottomed out on the track so got carted away..
3rd race was a no show due to damage...
the damage list is:
missing left rear spring and top hat
busted left rear shock
bent left front rim
2 flat front tyres
right front rim bent,squashed,fukt
right front shock bent like a banana
it was the most fun ever...
i have now fixed the shocks,got more rims and tyres.
17th jan, was meant to be modified champs in greymouth,so
was out in the shed sorting the car getting shocks set up and setting
bumper heights..
went to drive it out to load onto the truck and wouldnt get any get except 4th.
odd...even with the engine shut down no go..
it was idling for about 5mins when i noticed smoke from somewhere
and then a bearing noise,i knew it was from the engine cos it wasnt loud.
then i shut it down,popped the shifter off the turret and steam was coming from the box.
oil was milky as a white chocolate bar...looks like water had got into my box somehow..
had new oil before 1st race..
pulled the box out,took it to a mates place and we pulled it apart,a shit-load of
filings were inside,both layshaft bearings were toast from the milky oil...
and the input shaft bearing was marginal..
7:30pm last night after the box was stripped we went to the local speed/parts shop.
he stays open till like 11pm,got new layshaft bearings,ordered a new high load bearing
and even used his press to remove 2 of the shited bearings,the other we had to cut
off with a precision wharehouse grinder..
socket-pressed on the layshaft bearings,now just waiting for the main shaft bearing to arrive.
the situation with the gear sets aint too bad really..
the reverse gear has 1/4 of a tooth missing...but it will still work-hopefully..
the rest are fine.
then i also found that the shifter ball seat is missing,that would make gearchanges real shite.
but i guess well see how it goes once we get her back together..
thats all for now..
oh,also came up with a new paint scheme,but wanna do some graphics to go over it...
get your ideas in :wink:
righto so got the box back together and in the car.
checked for operation whith driveshaft off,then will it on
with wheels spinning,seemed to be all good except for 3rd,sometimes it wont
engage gear,itll just graunch,but if ya keep putting it in itll stay and work sweet.
only thing i can think of is that broken tooth..
unless a detent spring has been lost..
atleast i can say i didnt put it back together.. :rolleyes:
so if it doesnt go all to plan this weekend i will pull the engine out and
sell the chassis as a complete roller minus engine.
might keep the box and replace the gear and sell it,cos theyr super expensive.
i got myself a 3 speed hq box,so im damn stoked
got 4 monroe gas shocks to build new coilovers with.
just need to get the sleeves and nuts and top hats made up.
get new springs..but ill keep them for the new chassis..
oh but the best news is ive found someone whos coming over to greymouth
tomorrow to take my truck away and leave a trailer behind!!!!!
straight swap..
its a single axle,sprung,tilt deck.
its 3920x1850 deck size..
and hes just put a new wof on it!!!!
and repainted it and put on new boards....FRK yeah!
had the box out for a while now at work..
have found a few problems with it that ive been trying to iron out the bugs.
its actually easier to use bug spray than an iron...
got another clutch plate to put in so it should be back together this week..
on the weekend i went to nelson for the stock shock..
while i was there i picked up a set of rims for it..theyr like modgies but 15" and white.
also picked up a brand new Y body for the winter make over so shell look real spanky next season..
other things i need to do before the next meet i attend is to get a large thermo fan..
sort out a fuel leak on some hose joins near the tank.
get some 15 "inner tubes for the rear tyres and some 14s for the fronts so i can have some spares.
well...got the box back in with all the measuring,repairing some ones f ups,and put it together...
fired it up and what the f do you know....it works mint!!!
stoked....and just picked up a winch for the trailer for $10 and 2 wheels with new 8 ply tyres and a spare stockcar rim with mint tyre for $111 for the 3....so stoked..
still need the fan for this weekends racing..
and had a new arrival this week..my wife gave birth to a baby girl... 8)
last meeting for the season at greymouth this weekend with the KING of the COAST!!!
34 stockcars have been confirmed as entries....im one of them..
2 groups,highest placings after 2 heats will go onto the final race for the King of the Coast title.
hopefully there will be a hell bender race for the non-qualifiers so there will be mass carnage..
8 superstocks are also confirmed..
so now ive been given the day off work to get the car all ready for the big day...
need a new muffler for it to be legal..im sure its over 95db with the supertrapp.. :badgrin:
List of confirmed entries for King Of The Coast.
Modifieds
John Jackson 1 nz
Mike Gourley 4 c
Nigel Nevin 17 c
Scotty Lane 19 a
Brett Stack 46 c
Morris Headley 49 c
Steven Wockner 88 y
Super Saloons
Bruce Scott 4 c
Basil Jones 8 n
Trevor Elloitt 27 c
Mark Carey 35 n
Paddy North 46 e
Ron Taylor 71 n
Robert Jefcoate 96 n
? Flood 791 e
Mark McIntyre y
Street Stocks
Tim Smith 4 e
Stu Trevathan 7 n
Colin Robinson 8 c
Cody or Wayne McCarrison 9 e
James Carroll 10 e
Paul Walker 14 c
Sarah Kemp 26 n
Clynton Anderson 27 gm
Tim Kemp 39 gm
Michael Knipe 41 gm
Kieren Skurr 43 c
Keith Anderson 55 c
Charles Gardiner 68 c
Samantha Gowans 72 c
Alex Gowans 76 c
Andre Evans 77 n
Logan Atkinson 84 gm
Derek Buchanan
Ministocks
Alan Routhan 4 gm
Dave Houston Jnr 7 gm
Allan Meaclem 8 gm
Paul Murray 10 c
Sean Brown 14 gm
Josh Macgregor 16 c
Peter Reid 17 t
Gary Blackler 21 c
Steven Bellis 22 gm
Tony Newman 23 c
Jason Fox 27 y
RJ Ryder 27 y
Jono Garthley 33 c
Ben Jacob 41 c
Dave Houston Snr 44 gm
Chris Hall 47 c
Jayden Gerrard 48 gm
Samuel Gowans 54 c
Johnny Cox 56 c
Chris McSherry 61 y
Renee Murray 67 c
Shaun Cardwell 68 c
Whiskers 76 c
Graeme Porter 82 e
Shane Olsen 83 gm
Kirk Page 88 c
Stock Cars
Graeme Read 2 c
Jamie Routhan 4 gm
Colin Cameron 5 c
Matt Moir 7 c
Andrew Quy 10 n
Tony Stanton 11 gm
Ben Keys 14 n
Graham Nelson 15 gm
Vaughan Fairbairn 17 c
Gill Simpson 21 gm
Reece Ward 23 c
Stephen Bishop 24 c
Aaron Klempel 25 gm
Aaron Major 27 gm
Ralph Gillespie 28 e
Paul Ayres 31 gm
Jason Tasker 33 gm
Tony Oliver 38 gm
Jason Smith 43 gm
Murray Tapp 45 c
Robbie Martin 56 n
Cory Abernethy 61 c
Lloyd Jennings 64 c
Hadleigh Smith 68 gm
Gavin Marshall 69 e
Gavin Vallance 71 c
Steve Thomas 74 n
Dwayne Honey 82 gm
David Hern 84 c
Cody Streeter 87 c
Brad Hosking 89 n
Steve Biddolph 96 e
Russell Tuuta 98 c
Cleve Kokshoorn 99 gm
Productions
Ashley Boyd 4 gm
Brent Shearer 6 gm
Shawn Keen 8 e
Phil Campbell 9 y
Brent Wilson 14 gm
Steve Shearera 19 gm
Jason Fox 27 y
Allan Kirk 37 d
Lex Cummings 38 c
Voilet Cummings 39 c
Dan Horne 39 y
Cory Shearer 64 gm
Gerry Filius 68 c
Dave Filius 86 c
Scott James 88 n
Tony Diedrichs 93 n
Mike Harris 94 gm
Superstocks
Aaron Rowlands 14 c
Shane Harwood 18 n
Peter Field 27 c
Blair Cunningham 46 n
Ian Clayworth 117 n
Brett Nicholls 48 n
Brad Rosewarne 59 c
Jason Smith 89 c
King of the Coast went off today..
track was wet as,real pluggy..
i finished both heats with a total of 11 points,ended up tied on 17th with 2 other drivers.
coin toss put me back on grid 19 for the finish race..
was f---n stoked to qualify.
car was going bloody good,but my ability and skill level lacked a bit.
for some reason i kept spinning mid corner of 1&2..the rest was fine..
took some hits, gave some back, including a club member into the wall...sorry hads..not
i put a slider into 89n brad hosking but i got it in the side from another car...
the end result was a broken front arm which meant my front end was sliding left to right.
so that was the final done..
thoroughly enjoyed myself and looking forward to next season...
war of the wings and cromwell xmas champs!!!!!
Pics to come from todays effort..
race 2 was sweet,they got all tangled up and opened te door for me ae,as i was pinning it she got loose as,lost a bit of ground but damn that felt good knowing i could peddle passed the carnage..
one of my mates took some friggin epic shots,one of them im gonna get blown up and framed...
hes gonna put them on a cd for me so i guess i have to wait a few days for that..
