NewGuy Posted July 31, 2008 Share Posted July 31, 2008 I have got the timing at the factory spec of 10DBTDC Maybe even a bit more advanced Every thing seems to be mint. Plenty of power etc etc. But after it is revved over 5000rpm in 2nd and then you change to either 3rd or 4th and you try give her some gas it pings. If you take it easy it seems to be fine. I Then back the timing off a bit and adjust it to suite and then it feels as if it needs advancing again and all seems to be well. What could be creating such a change? Running 98Octane She is running cool as Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 31, 2008 Share Posted July 31, 2008 What do you mean it feels like it needs advancing?? Its laggy? What compression ratio you run? Id say its just not adjusted properly. Quote Link to comment Share on other sites More sharing options...
NewGuy Posted July 31, 2008 Author Share Posted July 31, 2008 What do you mean it feels like it needs advancing?? Its laggy?What compression ratio you run? Id say its just not adjusted properly. Yea feels laggy and missing power i dunno my compression is sposed to be 140psi and each cylinder is like 170psi. My ratio is in the parts book i have at home. Is there any chance the dizzy can change the advance at all? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 31, 2008 Share Posted July 31, 2008 So - It is pre-detonating under load A) You have planed your head and increased the compression ratio You have too much advance to be safe Solutions: 1) Back off the timing and live with it 2) Check cam timing to ensure that there is the correct valve overlap (more overlap reduces dynamic compression and assumes you have a twin cam) 3) Rip the head off and start again I vote for #1 Quote Link to comment Share on other sites More sharing options...
NewGuy Posted July 31, 2008 Author Share Posted July 31, 2008 Its running pretty rich aye. Idles at 850rpm to 1000rpm. Nah not high rpm just high load Say pulling 4th at 2000rpm and putting my foot flat it pinks. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 31, 2008 Share Posted July 31, 2008 ^ Instructions now edited. Classic symptoms Quote Link to comment Share on other sites More sharing options...
NewGuy Posted July 31, 2008 Author Share Posted July 31, 2008 ^ Instructions now edited.Classic symptoms I backed the timing of just a tiny amount and it goes heaps better doesn't pink at all. Even after multiple 5500Rpm Runs Quote Link to comment Share on other sites More sharing options...
NewGuy Posted July 31, 2008 Author Share Posted July 31, 2008 Also my coil gets really hot Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 31, 2008 Share Posted July 31, 2008 Also my coil gets really hot They do that Quote Link to comment Share on other sites More sharing options...
durty Posted July 31, 2008 Share Posted July 31, 2008 Also my coil gets really hot that can cause major problems, main way to test if its bad it to lick the contacts while its running Quote Link to comment Share on other sites More sharing options...
Requiemk Posted July 31, 2008 Share Posted July 31, 2008 lol, Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 31, 2008 Share Posted July 31, 2008 ^ Instructions now edited.Classic symptoms I backed the timing of just a tiny amount and it goes heaps better doesn't pink at all. Even after multiple 5500Rpm Runs As said before you just didnt have it right. The amount you twist the dizzy to change the advance is feck all, getting it right is alot of trial and error. Quote Link to comment Share on other sites More sharing options...
NewGuy Posted July 31, 2008 Author Share Posted July 31, 2008 Also my coil gets really hot that can cause major problems, main way to test if its bad it to lick the contacts while its running Fuck i LOLD Im still LOLing ^ Instructions now edited.Classic symptoms I backed the timing of just a tiny amount and it goes heaps better doesn't pink at all. Even after multiple 5500Rpm Runs As said before you just didnt have it right. The amount you twist the dizzy to change the advance is feck all, getting it right is alot of trial and error. Yea hopefully i can borrow a mint strobe over the weekend, feels to have more poke than before. Will see how it goes tomorrow. Cheers Boes Quote Link to comment Share on other sites More sharing options...
NewGuy Posted July 31, 2008 Author Share Posted July 31, 2008 Also anyone use those BOSCH GT40 Coils? Are they any good etc? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 31, 2008 Share Posted July 31, 2008 ??WTF? Are you doing this without a timing light and just based on static timing? If so you need to get a light on there before deciding anything Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted July 31, 2008 Share Posted July 31, 2008 well im prolly gonna get harassed for this BUT take off the vacuum advance .....loosen the locking screw grab dizzy....turn it one way so it just starts to idle up remember that spot.... now twist it the other way so it just starts to idle down ....now smack it in the middle between the 2 spots....... Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 31, 2008 Share Posted July 31, 2008 .. i did what vvega was saying but just left it were it rose in idle then drove if it pinked, backed off , repeat etc. my escort had 18 deg advance or somthing and ran mint well cept when vacuum lines broke , then all hell broke loose . either way get a fuckin timing light and do it properly then you can start from square one and wonder off where if you want to Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 31, 2008 Share Posted July 31, 2008 ^ I was about to ask what a mechanic was doing without a timing light............... and then I remembered. Diesel Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 31, 2008 Share Posted July 31, 2008 Also anyone use those BOSCH GT40 Coils?Are they any good etc? I use one, is mint. Supercheap seem to sell them cheapest. Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 31, 2008 Share Posted July 31, 2008 ^ I was about to ask what a mechanic was doing without a timing light............... and then I remembered.Diesel HEY i can time and tune petrols just fine thanks , cna tune diesel pumps better though , usuaslly cos they have line that you line up and BANG ! , unless it s ve pump .. then they are all and need to be dial timed etc. or spill timed , which is piss easy Quote Link to comment Share on other sites More sharing options...
