pies Posted April 8, 2008 Share Posted April 8, 2008 How can i tell if a w series gearbox bell housing will fit an m series engine? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 8, 2008 Share Posted April 8, 2008 G bellhousing off a 1981 GX61 Chaser 1GEU motor. S bellhousing - SX6x Mark II, Cressida etc. Also C bellhousing the same - CA60 Carina wagon, CM30? Liteace with G52 gearbox (same bolt pattern as W series gearbox). Y bellhousing - YX70 Mark II wagon, YM30 Liteace with G52 gearbox (same bolt pattern as W series gearbox). Can be used on a S motor to put starter on other side of block if the top right hole is slotted See the hole in the top right is slightly lower than the S/C bellhousing. R bellhousing - RX30? Cressida M bellhousing - MA60, MA70 Supras Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 8, 2008 Share Posted April 8, 2008 ...can't find out what motor they come off, he got them with his spare 5M when he bought that from the crazy convert it to rangi carb stockcar guy up in central otago. Like I said in the other thread though, says "Toyota Crown 2.6litre 4speed" on them.. so, that would be what? 4M? likely to W40? Are 4 - 5spd W bellhousings the same? tgb? oh fountain of gearboxicle knowledge. Quote Link to comment Share on other sites More sharing options...
pies Posted April 8, 2008 Author Share Posted April 8, 2008 ...can't find out what motor they come off, he got them with his spare 5M when he bought that from the crazy convert it to rangi carb stockcar guy up in central otago.Like I said in the other thread though, says "Toyota Crown 2.6litre 4speed" on them.. so, that would be what? 4M? likely to W40? Are 4 - 5spd W bellhousings the same? tgb? oh fountain of gearboxicle knowledge. im guessing, since most crowns were auto? it woudl be connected to an auto 4 speed Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 8, 2008 Share Posted April 8, 2008 4 and 5 speed W40/50 housings are the same. would be an M series bell by the description you've given me. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 8, 2008 Share Posted April 8, 2008 also compare the bolt pattern in those pics of the gearbox to the bellhousings you've got to see if it suits a auto or manual box Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 8, 2008 Share Posted April 8, 2008 These seem entirely different than the MA60/70 one, using that picture as reference. Probablee not goot for za fiving speedz maybes? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 8, 2008 Share Posted April 8, 2008 Arg w50 is different to w55/etc, can't remember off the top of my head what the bolt pattern is like.. Edit: That looks the same as the one you posted KY Also searching for W40's on TM found this http://www.trademe.co.nz/Trade-Me-Motor ... 69.htm?p=3 looks like its alloy case 4 speed. probably a T40? Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 8, 2008 Share Posted April 8, 2008 Ner, that one I posted is mot definately M-series based on the MA60/70 pictures the confusing part is what gearbox actually bolts onto it. Doesn't appear to be W55 anyway, so no good for pies. Sorry sweety. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 8, 2008 Share Posted April 8, 2008 Gaybuzz. If its for a R series motor should give it to me Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 8, 2008 Share Posted April 8, 2008 Whut? It's for M-engine Dirty R, ewww. Just need to find out what box sits on the back of it T40/50 W40/50. That's assuming the W55/57 have a different bolt pattern to to the 40/50 Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 8, 2008 Share Posted April 8, 2008 If your certain it fits M series its a M to W50. Has the same bolt spacing for the box as that one in the pic, its just cos its got that yuck Holden bell over it. Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 8, 2008 Share Posted April 8, 2008 Oh true true, I see now. Just had to make a mental note of the positioning of the input shaft in relation to the bolts. Makes sense now. My mistake. I believe you are correct oh mighty Ben. You are the greatest of Ben's. Quote Link to comment Share on other sites More sharing options...
pies Posted April 9, 2008 Author Share Posted April 9, 2008 Oh true true, I see now. Just had to make a mental note of the positioning of the input shaft in relation to the bolts. Makes sense now.My mistake. I believe you are correct oh mighty Ben. You are the greatest of Ben's. soo... does this mean it will fit my w55 box? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 9, 2008 Share Posted April 9, 2008 Nah. Also people want moon beams for W55/7/8 to M series bellhousings. Sucks to be YOU! Quote Link to comment Share on other sites More sharing options...
pies Posted April 9, 2008 Author Share Posted April 9, 2008 will it fit w50? Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 9, 2008 Share Posted April 9, 2008 Yuh, what Ben said. Sorry boe. At least one new post has been made to this topic. You may wish to review your post in light of this. will it fit w50? Using those pictures as reference ..yuh. Should fit the W40/50. Just not the 55/57. Quote Link to comment Share on other sites More sharing options...
pies Posted April 9, 2008 Author Share Posted April 9, 2008 men. cos im gonna try get me a w50 for temporarys, then sell it to ben for ute. how much your bro want for bellhousing? Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 9, 2008 Share Posted April 9, 2008 Fuckall probably. He's at work, will find out tonight for you. Quote Link to comment Share on other sites More sharing options...
pies Posted April 9, 2008 Author Share Posted April 9, 2008 Fuckall probably. He's at work, will find out tonight for you. Quote Link to comment Share on other sites More sharing options...
