Escort electrics........
nick 401
Hey was wanting to know if anyone has any idea why my escort wont run??
Basically start it up and it runs mint, then after about 5mins once its warmed up it dies and nothing works, no lights, horn etc..... After its cooled down again it starts back up fine until it heats up and dies again..
So if anyone has any suggestions i would be stoaked 2 here em.
cheers
If it is electrical id say cross out coil, alt, dizzy, leads, plugs as they wont stop ya lights etc.
Id be looking into ya fuse box to see if anything weird is in there that heats up, expands and shorts stuff out. (not that likely tho)
Also check relays if ya have any (im pretty sure they just stop working but could be a prob)
Check main battery feed for splits in cable or any sign of excess heat.
Have you tried replacing battery? It sounds like it will be coming from battery, main power supply cable or a main relay/fuse that supplies all power to ignition.
Just my 5c.
p.s what motor are you running?
Ah its running a 1600 711m block with a lightened balanced bottom end etc.... cam, head work and 40mm dellorto dlha's.
And so hows ya van coming along? haven't seen an update in a while, is lookin pretty sweet.
And thanks for ya help peoples ill have a look into it this w.e..
its coming along mate had friends out from the uk so havnt realy done much in the past month .hoping to get most of the inside done this weekend .i got all the sounds made up and in just want to get it painted.
im in chch so if you want a hand just give me a pm mate.
cheers
dan
Cool sounds good, cant wait to see it, and yea thanks mate.
