johnnyfive Posted February 14, 2008 Share Posted February 14, 2008 So I've been pulled in to help a friend whos just replaced the engine in his AE101 Levin. It runs (somehow), but the warmer it gets the worse the idle is and throttle is needed to keep it running. If you let it die, it will only start and run at WOT and very badly. Once it cools down, it behaves itself again. Checked spark, & has fuel to injector rail, I don't know where to start/can be fucked. Not sure where to look next. Any 4age boes have a clue? Quote Link to comment Share on other sites More sharing options...
CXGPWR Posted February 14, 2008 Share Posted February 14, 2008 chech temp sender unit to ecu, check idle control valve, check air flow meter, Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 15, 2008 Share Posted February 15, 2008 temp sender? Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 15, 2008 Share Posted February 15, 2008 temp sender? yup its the 2 wire one thats not the switch for the fan on the thermo block right hand side of the head. If this is fucked ecu will think all sorts of whack shits going on doesnt sound like a typical temp sender fault but you never know. Pull the codes bro edit whoops Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted February 15, 2008 Author Share Posted February 15, 2008 May go have another tinker this weekend Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted February 18, 2008 Author Share Posted February 18, 2008 Swapped temp sensor from orig engine over. Unsure if it was wrong sensor or just a fucked one. Seems to work all dandy. I am still so surprized my friend got the thing together, found like 50% of things loose & hoses etc going random places. Heard some pretty funky noises on the test drive.. Anyway, done my part. Thanks boes! Quote Link to comment Share on other sites More sharing options...
