nothingsfree Posted January 25, 2008 Share Posted January 25, 2008 Sorry bro, quoted wrong thing. Was asking rxsmidy... Anyway, your 10a turned up yet? Quote Link to comment Share on other sites More sharing options...
shizzl Posted January 25, 2008 Author Share Posted January 25, 2008 should be here tomorrow or monday Quote Link to comment Share on other sites More sharing options...
shizzl Posted January 28, 2008 Author Share Posted January 28, 2008 http://www.trademe.co.nz/Browse/Listing ... =137535913 have a look at this escort...exactly what i had in mind.. itll work,and i WONT need to modify the pedal box to do it,or mess with the stock clutch cable.. to me it doesnt look like the tunnel has been chopped,what do you guys think? Quote Link to comment Share on other sites More sharing options...
shizzl Posted January 29, 2008 Author Share Posted January 29, 2008 10a arrived today.... gearbox seems fairly small...so shouldnt be a huge problem Quote Link to comment Share on other sites More sharing options...
shizzl Posted April 14, 2008 Author Share Posted April 14, 2008 check out this thing.changes your set up from cable-hydr Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 14, 2008 Share Posted April 14, 2008 ^^ That looks like a pricey peice of kit that you dont need. Just make one yourself. Also re tunnel, dont bother getting anything bent up or anyhting now. Fit gbox and cut out everywhere it fouls. Make sure it has at least 2 finger gaps all way round.. Put gbox on engine and jack under tailshaft, also have driveshaft in and conected to diff. Then jack box up as far as you can untill it fouls.. Find where it fouls and repeat.. Keep doing this untill you get the driveshaft level or as close to as you want.. (remember it will change when you lower your car. Then you start making new part to go back over holes. Chances are you will just need a patch or two rather than a full tunnel cut. Quote Link to comment Share on other sites More sharing options...
shizzl Posted April 14, 2008 Author Share Posted April 14, 2008 was just gonna buy the steel for it cos i live in fox glacier,thats 2.5hr from greymouth and 5.5hr from chch,no steel shop here... that cable-hyd thingy i can make myself.. thats if i can get a new slave for the box.. i dont have a driveshaft for it yet,ill need to locate a yoke.. was alos thinking of putting in a hilux diff as the early ones bolt straight in apparently.. if im gonna start cutting it up for the 10a and box to fit i might aswell go all out on everything else aswell ae. just gotta find a way to get the front hubs to 5 stud without being too damn expensive.. Quote Link to comment Share on other sites More sharing options...
OSC Posted April 14, 2008 Share Posted April 14, 2008 meh 10a is ftw for different factor hence why i wanna keep 1600 in my mk1. and just go get a clutch m/c and cut approprite size holes and mount it. all u gotta work out is how much travel u need for a 95% m/c stroke. then find the point along the clutch pedal that moves this much when u push the clutch in. next u make a bracket that can pivot to fit ur m/c pushrod to and hey presto eski hydraulic clutch just did one on my mk2. use a ae86 m/c just coz toyota shit is ftw and because they have a thread on the pushrod that allows for adjustment. Quote Link to comment Share on other sites More sharing options...
shizzl Posted April 14, 2008 Author Share Posted April 14, 2008 ^^ haha yeah,.. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted April 14, 2008 Share Posted April 14, 2008 Cant remember fully but someone said to use zephyr front hubs for the 5 stud conversion? Quote Link to comment Share on other sites More sharing options...
eskynut Posted April 14, 2008 Share Posted April 14, 2008 already got a 10a,it turns up in 2days..any idea where to locate the PDF? Link for rally prep manual http://www.siipicossu.com/manuaaleja/manuaalit.htm go down page till find escort rally prep manual about 20meg download Quote Link to comment Share on other sites More sharing options...
