d.p.n.s Posted January 4, 2008 Share Posted January 4, 2008 hi all ive just finished wiring up my escort for a 2.0 it turns over fine but wont start... ive pulled out one of the plugs and theres no spark any ideas please. cheers dan Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 Have you got power going to the coil? What voltage coil are you running and are you using the ballast? Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 4, 2008 Share Posted January 4, 2008 Do you have NO spark or just weak spark. Check at night time as if you just have VERY weak spark id say it is.... starter wired wrong Extra terminal on back of starter motor (aucillary contact).. Is there to get extra voltage to coil when cranking. As above ya should have a ballest coil and resitor also. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 Have you got power going to the coil?What voltage coil are you running and are you using the ballast?[/quo yes ive got power to the + on the coil the coil itself is one that came with the motor so im hoping its 12 volt Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 As above ya should have a ballest coil and resitor also. I didn't say that lol I recommend ditching the ballast and running a good relayed 12v feed to a 12v coil Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 and gaz there is no spark at all. i have the starter wired up the way the guys on turbosport advised me how. Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 yes ive got power to the + on the coilthe coil itself is one that came with the motor so im hoping its 12 volt Have you got a multi meter to check what voltage? And is the ballast wired up? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 yes ive got power to the + on the coilthe coil itself is one that came with the motor so im hoping its 12 volt Have you got a multi meter to check what voltage? And is the ballast wired up? no i dont mate and jog my memory whats the ballast? Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 It lowers the voltage going to the coil to 9v (i think its 9v), the extra wire on the starter is so the coil sees 12v when cranking to boost the spark on start up. I'd try disconnecting the + wire from the coil and running a 12v feed straight from the battery. if it starts up like that i'd rewire the coil Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 It lowers the voltage going to the coil to 9v (i think its 9v), the extra wire on the starter is so the coil sees 12v when cranking to boost the spark on start up.I'd try disconnecting the + wire from the coil and running a 12v feed straight from the battery. if it starts up like that i'd rewire the coil still nothing man Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 Ok, could be dead coil or could be something up with the dizzy, what are your points like? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 Ok, could be dead coil or could be something up with the dizzy, what are your points like? they look new its got new plugs aswell the only thing is mate i dont know if the timing is right or even iv the leads are around the right way for all i know the guy could have just struk them eny old way. Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 the only thing is mate i dont know if the timing is right or even iv the leads are around the right way for all i know the guy could have just struk them eny old way.Would still have spark at the plugs, have you got another coil to try? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 the only thing is mate i dont know if the timing is right or even iv the leads are around the right way for all i know the guy could have just struk them eny old way.Would still have spark at the plugs, have you got another coil to try? ive got another 2 coils not new but i tryed them and still no spark ..... so it has to be the dizzy right?... Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 4, 2008 Share Posted January 4, 2008 Yeah to me its got to be dizzy now, you have checked that the points are opening and closing all good aye? No brakes in the wire from the points to the coil -? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 4, 2008 Share Posted January 4, 2008 Have you got a timing light handy? Als check the dizzy cap hasnt been knocked/got any cracks in it, and are the points gapped properly. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 4, 2008 Author Share Posted January 4, 2008 Yeah to me its got to be dizzy now, you have checked that the points are opening and closing all good aye?No brakes in the wire from the points to the coil -? ill leave it for now mate had enoght for 1 day.. ill go and get a new coil and points 2morow just to make ure and then just go from there. thanks mate .... ill probly be on here 2morow. cheers again dan Quote Link to comment Share on other sites More sharing options...
sholdowa Posted January 4, 2008 Share Posted January 4, 2008 Also it'd be worth trying a new ht lead from the coil to distributor. That and the lt are the only other stuff that are common to all cylinders. Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 4, 2008 Share Posted January 4, 2008 $100 should get ya new coil, points, leads and maybe dizzy if you get trade. prob a good $100 spent as they wont fuck up again then. Might as well get rotor too in that case. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 5, 2008 Author Share Posted January 5, 2008 ok so ive got it to fire but i think the firing order is up the fuk. so if any one can tell me the right way and starting from were on the dizzy cap ill be able to do the timeing from there. cheers dan Quote Link to comment Share on other sites More sharing options...
