Urgent. Help reomoving special bolts.
treggo
I have remove countless of these on japa lasers/323's -
You need a sharp centre punch. Punch a starting divot into it - then using the punch as a drift, tap it firmly counterclockwise it will undo slowly - getting faster as it loosens. Then do the other one..
Locksmith should have a good idea how to do it if you dont.
To put it back on you will need to buy replacement torque to yield bolts.. just tighten it to a nice snug tightness - then back it off a quarter turn sharply and the bolt head will snap off as it is meant to - or you can just leave the head on there for next time you loose your keys, if you undo it carefully the head won't snap off.
Guest sexychevette
screw a screw into the key hole and pull it out with a claw hammer. then break steering lock with ur muscles :P
lol: thats how we sorted my econovan when we couldnt find the keys and this old hippie who lives in a bus was there to pick it up. We is smarts
