Ke36 Posted October 17, 2007 Share Posted October 17, 2007 hey guys just trying to connect up my heater pipes and i forgot to label them which was in and out when i took them off (the outlets at the firewall) can someone with a stock(ish) ex lancer have a looksee for me? cheers Quote Link to comment Share on other sites More sharing options...
Ke36 Posted October 19, 2007 Author Share Posted October 19, 2007 any one? does it matter which one i put on which or can i just go either, either i assume its just flows through the core but dont want to end up with water all over my cabin floor cos i hook them up backwards and the pressure built up in the core cos theres a valve that only opens when you turn the heater on or something cheers Quote Link to comment Share on other sites More sharing options...
Ogre Posted October 20, 2007 Share Posted October 20, 2007 i think the right hose is the intake i think...... Quote Link to comment Share on other sites More sharing options...
Ke36 Posted October 23, 2007 Author Share Posted October 23, 2007 ok scrubb kindly took this pic for me there the two pipes hes not sure which is which though ive asked him to trace them to where they go and hopefully should be able to work it out another quick qustion i have is waht side of the tank is the fuel tank pickup? i got both my fittings changed to the same size and now i cant remeber 100% which is the pickup i think it was the drivers side one but if someone could have a quick peek for me thatd be mint itl be the larger pipe coming out of the fuel tank they are over by the passenger rear wheel cheers Quote Link to comment Share on other sites More sharing options...
Scrubb Posted October 23, 2007 Share Posted October 23, 2007 looks like that left one goes on higher than the right and the right one goes on somewhere underneath? is it possible to find places where hoses are meant to be and hook them up? if not I can try and trace where they go and take more pics Quote Link to comment Share on other sites More sharing options...
rxtoy Posted October 23, 2007 Share Posted October 23, 2007 one of them goes to a steel pipe that runs from the rear passenger side of the block, around behind it then up to the front end of the block to the water pump (or something like that). sorry, can't remember which one, i just remember my pipe getting a little too thin so i made one up from copper to replace it. was a mission getting it in and out but can be done. i think the other one comes off from your inlet manifold or the back of the head??? if you get desparate just block them both off (the engine side, not the heater side) so you can run it, go find someone else with an EX and park it up next to them. sorry couldn't be more help, its been a while since i played with mitis's. cheers Matt Quote Link to comment Share on other sites More sharing options...
Ogre Posted October 23, 2007 Share Posted October 23, 2007 when looking at that pic, the "closer" pipe runs to a steel pipe that routs around the other side of the block and into the water pump.That the "outlet" for the heater.ie, the other is the ntake/hot bit etc.Other hose runs off the intake manifold on the 1200s, comes out the the side of the head (i think) on the 1600s. fukn bang Quote Link to comment Share on other sites More sharing options...
Scrubb Posted October 23, 2007 Share Posted October 23, 2007 Should mention that pic is 1600 lol Quote Link to comment Share on other sites More sharing options...
macabre Posted October 23, 2007 Share Posted October 23, 2007 hrmm i need to sort my heater out too, have to make some shit i guess Quote Link to comment Share on other sites More sharing options...
P_Star Posted October 23, 2007 Share Posted October 23, 2007 hrmm i need to sort my heater out too, have to make some shit i guess /nah, its summer Quote Link to comment Share on other sites More sharing options...
Ke36 Posted October 24, 2007 Author Share Posted October 24, 2007 when looking at that pic, the "closer" pipe runs to a steel pipe that routs around the other side of the block and into the water pump.That the "outlet" for the heater.ie, the other is the ntake/hot bit etc.Other hose runs off the intake manifold on the 1200s, comes out the the side of the head (i think) on the 1600s.fukn bang thats y i fuckin lub u mang Quote Link to comment Share on other sites More sharing options...
macabre Posted October 24, 2007 Share Posted October 24, 2007 hrmm i need to sort my heater out too, have to make some shit i guess /nah, its summer true, but it will help to cool engine when in heavy summer traffic Quote Link to comment Share on other sites More sharing options...
Scrubb Posted October 24, 2007 Share Posted October 24, 2007 The left pipe goes into the side of the head at the back. The right hose goes down into a piece that has another pipe coming off it to the intake manifold and a Steel pipe going all the way around the back of the engine and into the water pump but I dont know which is in/out. Looked under car but I have no idea what I'm looking at for the fuel tank hoses.. Couldnt see anything but I didnt go right underneath car. Quote Link to comment Share on other sites More sharing options...
Ke36 Posted October 24, 2007 Author Share Posted October 24, 2007 cheers man thats confirmed it right hose(passenger) is return, left is inlet (gets hot water from block) for the fuel pipes the fuel tank is right underneath the boot, at the forward part of it, on the passenger side there are too pipes coming out of it just want to know which is the larger of the two pipes the driver or passenger side one (larger one will b the pickup) ud hafta get right under too see Quote Link to comment Share on other sites More sharing options...
Scrubb Posted October 25, 2007 Share Posted October 25, 2007 Looked under car a few secs ago.. theres 2 pipes going into the fuel tank by the rear passanger wheel, both pretty much same size but the one on the passenger side is slightly bigger Hope that helps Quote Link to comment Share on other sites More sharing options...
Ke36 Posted October 25, 2007 Author Share Posted October 25, 2007 cheers mate yea slightly bigger one will be pickup Quote Link to comment Share on other sites More sharing options...
