zep Posted August 12, 2007 Share Posted August 12, 2007 Hey guys.. I need to restud my Hilux axles with longer studs. The problem is that because of the length of the new ones, the backing plate which bolts to the diff gets in the way and I can't get them in. Obviously I need to separate this from the hub on the axle. How do you do this? I'm assuming you remove the circlip behind the plate then use a press? Am I better off sending the axles into steelie gears and getting them to do it (as I could damage them/dont have a press and would prolly use a hammer)? Cheers Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 13, 2007 Share Posted August 13, 2007 Kinda a bit unsure of what ya mean. Do you have the axles out already? If not then I think its four bolts holdeing em on then just use a slide hammer to pop the axle out. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted August 13, 2007 Share Posted August 13, 2007 ^ I think he means that the anchor plate/bearing retainer that you refer to needs to come off the axle as the studs are so long. Not something I have struck before.... they must be bloody big plates on the Hilix diffs Quote Link to comment Share on other sites More sharing options...
kpr Posted August 13, 2007 Share Posted August 13, 2007 must mean the backing plates the drum brake stuff is on. the bearing holder bit isnt big enough to get in the way. thought they just unbolted? been along time since i chucked that shit in the bin tho Quote Link to comment Share on other sites More sharing options...
Unclejake Posted August 13, 2007 Share Posted August 13, 2007 Pics or ban Zep Quote Link to comment Share on other sites More sharing options...
zep Posted August 13, 2007 Author Share Posted August 13, 2007 fark... i rang steelie gears, gonna send them over there tomorrow... I will post a pic out of interest later tho... Quote Link to comment Share on other sites More sharing options...
